UN9GW а у ао-51,VO-52 какая поляризация?
Так как многие спутники вращаются желательно иметь круговую поляризацию.Чтоб избавиться от замираний достаточно иметь с одной стороны круговую,или на земле или на sat,с двух сторон необязательно.
VO-52 HAMSAT
Catalog number: 28650
Launch Date: May 05,2005
Status: Operational
Current Mode: U/V - Indian Transponder
Frequencies:
Indian Transponder:
Uplink: 435.220 to 435.280 MHz LSB/CW
Downlink: 145.870 to 145.930 MHz USB/CW
Dutch Transponder:
Uplink: 435.225 to 435.275 MHz LSB/CW
Downlink: 145.875 to 145.925 MHz USB/CW
Indian Beacon: 145.859330 MHz CW
Dutch Beacon: 145.860 MHz 12WPM with CW message
Mode and Antenna Polarization:
V: LHCP
U: RHCP
Official Webpage: http://www.amsat.in/hamsat.htm
To know what transponder is switched on please listen for the beacon
that is
active. Each transponder has a different beacon.
[10022006]
AO-51 ECHO
Catalog number: 28375
Launch date: June 29, 2004
Status: Voice Repeater ONLY - Software reload in progress
Telemetry Downlink
Current Mode(s): FM Repeater - V/U
PBBS - OFF
Digipeater - OFF
Telemetry - /U
Analog voice downlink: 435.300 MHz FM
435.150 MHz FM
2401.200 MHz FM
Analog voice uplink: 145.880 MHz FM
145.880 MHz USB
145.920 MHz FM
1268.700 MHz FM 67Hz PL tone
Digital Downlinks: 435.150 MHz FM 38k4 Digital, PBP, 1 watt output
435.150 MHz FM 9k6 Digital, Pacsat Broadcast
Protocol
2401.200 MHz FM 38k4 bps, AX.25
Digital Uplink: 145.860 MHz FM 9k6 Digital, Pacsat Broadcast
Protocol
1268.700 MHz FM 9k6 PBP Digital
Beacon: 435.150 MHz
T: Linear
V: Linear
U: TX A (usually digital)LHCP
TX B (usually analog) RHCP
L: Linear
S: Linear
Broadcast: PECHO-11
BBS: PECHO-12
Official Webpage: http://www.amsat.org/amsat-new/echo/
[05072007]
SO-50 SAUDISAT-1C
Catalog number: 27607
Launched: December 20, 2002
Status: Operational.
Uplink: 145.850 MHz FM - 67.0 Hz PL tone
Downlink: 436.795 MHz
V: Linear
U: Linear
Official Webpage: http://saudisat.kacst.edu.sa/index.shtml
(not up and running currently)
To switch the transmitter on, you need to send a CTCSS tone of 74.4 Hz.
The order of operation is thus: (allow for Doppler as necessary):
1) Transmit on 145.850 MHz with a tone of 74.4 Hz to arm the 10 minute
timer
on board the spacecraft.
2) Now transmit on 145.850 MHz (FM Voice) using 67.0 Hz to PT the
repeater on
and off within the 10 Minute window.
3) Sending the 74.4 tone again within the 10 minute window will reset
the 10
minute timer.
[03262007]
AO-27 AMRAD
Catalog number: 22825
Launched: September 26, 1993
Status: Operational
Downlink: 436.795 MHz FM
V: Linear
U: Linear
Official Webpage: http://www.ao27.org
[03262007]
AO-7 AMSAT OSCAR 7
Catalog number: 07530
Launch Date: November 15, 1974
Status: Operational depending on amount of Sunlight
Uplink: 145.850 to 145.950 MHz CW/USB Mode A
432.125 to 432.175 MHz CW/LSB Mode B
Downlink: 29.400 to 29.500 MHz CW/USB Mode A (1W PEP)
145.975 to 145.925 MHz CW/USB Mode B (8W PEP)
145.975 to 145.925 MHz CW/USB Mode C (2W PEP)
Beacons: 29.502 MHz CW
145.972 MHz CW
435.100 MHz CW
2304.100 MHz CW
Official Webpage:
http://www.amsat.org/amsat-new/satellites/sat_summary/ao7.php
The AO-7 Logbook and Resource Website:
http://www.planetemily.com/ao7/
AO-7 Usage Guidelines on the AO-7 Log and Resource Site located at:
[02262007]
INTERNATIONAL SPACE STATION (ISS) - ARISS
Catalog number: 25544
Launch date: November 20, 1998
Status: Operational
Current Mode: Occasional Voice
Digipeater: OFF
Expedition 15 crew:
Commander: Fyodor Yurchikhin RN3FI
Flight Engineer: Charles Simonyi KE7KDP/HA5SIK
Flight Engineer: Sunita Williams KD5PLB
Digital/APRS:
Worldwide packet uplink: 145.990 MHz FM
Worldwide packet downlink: 145.800 MHz FM
Voice:
Region 1 voice uplink: 145.200 MHz FM
Region 2/3 voice uplink: 144.490 MHz FM
Worldwide downlink: 145.800 MHz FM
SSTV TESTING:
Worldwide Reported Downlink: 145.800 MHz FM
Crossband Repeater:
Repeater Uplink: 437.800 MHz FM
Repeater Downlink: 145.800 MHz FM
V: Linear
U: Linear
Callsigns:
German: DP0ISS
Russian: RS0ISS, RZ3DZR
USA: NA1SS
Packet Mailbox: RS0ISS-11
Packet Keyboard: RS0ISS-3
Digipeater callsign: ARISS
Official ARISS Webpage: http://www.rac.ca/ariss
ISS Fan Club Webpage: http://www.issfanclub.com
APRS tracking page: http://www.ariss.net/
ISS Daily Crew Schedule: http://spaceflight.nasa.gov/station/timelines/
Remember that the crew operates on UTC time. Also, all of the time line
is
NOT translated from Russian and posted.
[04232007]
NNNN
/EX
SB SAT @ AMSAT W8ISS $ANS-127.S2
WSR 127 Part 2 05/07/2007
AMSAT NEWS SERVICE BULLETIN 127.S2 FROM AMSAT HQ
SILVER SPRING, MD, May 07, 2007
TO ALL RADIO AMATEURS
BID: $ANS-127.S2
CAPE1
Catalog Number:
Launch Date: April 17,2007
Status: In Orbit
Downlink: 435.245 MHz 9600 bs FSK AX.25
[04232007]
CP3
Catalog Number:
Status: In Orbit
Downlink: 436.845 MHz 1200 bps FSK AX.25
[04232007]
CP4
Catalog Number:
Status: In Orbit
Downlink: 437.325 MHz 1200 bps FSK AX.25
[04232007]
Libertad-1
Catalog Number:
Launch Date: April 17, 2007
Status: In Orbit
Downlink: 437.405 MHz 1200 bps AFSK AX.25
[04232007]
PO-63 PEHUENSAT-1
Catalog Number: 29712
Launch Date: January 10, 2007
Status: In Orbit
Uplink/Downlink: 145.825 MHz FM
Voice Recorder: 145.825 MHz FM
[02052007]
?O-?? FCAL
Catalog Number: 29667
Launch Date: December 21, 2006
Status: In Orbit
Downlink: 437.385 MHz APRS AX25
Downlink ID: KD4HBO
Website: http://eng.usna.navy.mil/~bruninga/fcal.html
[02262007]
NO-61 ANDE
Catalog Number: 29664
Status: In Orbit
Uplink/Downlink: 145.825 MHz FM APRS AX25
[01222007]
NO-60 RAFT-1
Catalog Number: 29661
Status: In Orbit
Main Downlink: 145.825 MHz FM APRS AX25
APRS Uplink: 145.825 MHz FM APRS AX25
Voice/PSK31 Uplink: 28.120 MHz
Packet to Voice ID: RAFT
[02262007]
GENESAT-1 ?O-??
Catalog Number: 29655
Launch Date: December 16, 2006
Status: Operational
Telemetry Beacon Downlink: 437.0670 MHz AFSK 1200 BPS
Official webpage: http://www.crestnrp.org/genesat1/ahc.html
[01082007]
HO-59 HITSat
Catalog number: 29484
Launch date: September 22, 2006
Status: Operational
Telemetry Downlink: 437.4250 MHz AFSK 1200 BPS
Beacon: 437.2750 MHz CW
Callsign: JR8YJT
[10302006]
CO-58 CubeSat XI-V
Catalog number: 28895
Launch Date: October 27, 2005
Status: Operational - CW Beacon only
Telemetry Downlink: 437.4250 MHz AFSK 1200bps using AFK protocol
Callsign: JQ1YGW
Official Webpage: http://www.space.t.u-tokyo.ac.jp/cubesat/mission/V/
Pictures received by Mineo Wakita - JE9PEL:
http://www.ne.jp/asahi/hamradio/je9pel/
[03262007]
CO-57 CubeSat XI-IV
Catalog number: 27848
Launched: June 30, 2003
Status: Operational
Beacon: 436.8475 MHz CW
Telemetry : 437.4900 MHz AFSK 1200 BPS
Callsign: JQ1YGW
[01082007]
CO-56 CUTE-1.7 + APD
Catalog number: 28941
Launched: February 21, 2006
Status: Semi-Operational - Constant Carrier only
Uplink: 1268.5000 MHz GMSK 9600 BPS
Downlink: 437.4700 MHz 1200 FM ax25 or SRLL (ACTIVE only near Japan ? )
Telemetry Beacon: 437.3850 CW
Callsign: JQ1YPC
Information webpage:
http://lss.mes.titech.ac.jp/ssp/spacerium/cute1blog/
[01082007]
AO-51 ECHO
Telemetry Downlink
PBBS - OFF
Digipeater - OFF
Telemetry - U
435.150 MHz FM
2401.200 MHz FM
145.880 MHz USB
145.920 MHz FM
Protocol
Protocol
Beacon: 435.150 MHz
T: Linear
V: Linear
L: Linear
S: Linear
Broadcast: PECHO-11
BBS: PECHO-12
[05072007]
NO-44 PCSAT
Catalog number: 26931
Launch Date: September 30, 2001
Status: Operational only in Full Sun Light
General Usage Uplink/Downlink: 145.827 MHz 1200 Baud
Special Usage Downlink: 144.390 MHz 1200 Baud
PCSAT APRS page: http://pcsat.aprs.org
aprstlm Telemetry Decoder program:
http://www.xciv.org/~iain/aprstlm/v1.2/
[01082007]
GO-32 Gurwin TechSat-1B
Catalog number: 25397
Launch Date: July 10, 1998
Status: Operational
Downlink: 435.225 MHz FM (9600-baud FSK)
435.325 MHz - Not Available - temperature problems
Uplinks: 145.850 FM
145.890 FM
145.930 FM
1269.700 FM
1269.800 FM
1269.900 FM
Broadcast Callsign: 4XTECH-11
BBS Callsign: 4XTECH-12
More information of GO-32 can be found at:
http://www.iarc.org/techsat/techsat.html
[03262007]
AO-16 PACSAT
Catalog number: 20439
Launch Date: January 22, 1990
Status: Semi-operational - APRS usage through Digipeater
Uplink: 145.900 MHz FM 1200-baud Manchester FSK
145.920 MHz FM 1200-baud Manchester FSK
145.940 MHz FM 1200-baud Manchester FSK
145.960 MHz FM 1200-baud Manchester FSK
Downlink: 437.026 MHz SSB 1200-baud PSK
Mode-S Beacon: 2401.1428 MHz
U: RC 437.050 MHz RHCP
PSK 437.025 MHz LHCP
V: Linear
Broadcast Callsign: PACSAT-11
BBS: PACSAT-12
AO-16 AMSAT Webpage: http://www.amsat.org/amsat/sats/n7hpr/ao16.html
[03262007]
UO-11 OSCAR-11
Catalog number: 14781
Launched: March 1, 1984
Telemetry Downlink: 145.826 MHz. FM 1200 AFSK
Mode-S Beacon: 2401.500 MHz - OFF
UHFBeacon: 435.025 MHz - OFF
V: RHCP
S: LHCP
Official webpage: http://www.users.zetnet.co.uk/clivew/
MPEG3 files: http://www.ne.jp/asahi/hamradio/je9pel/uo11tlme.htm
[01082007]
Status: Operational
Digipeater: OFF
Expedition 15 crew:
Digital/APRS:
Voice:
SSTV TESTING:
Crossband Repeater:
V: Linear
U: Linear
Callsigns:
German: DP0ISS
USA: NA1SS
is
[04232007]
NNNN
/EX
