Автор Тема: EME-DXPEDITION  (Прочитано 192698 раз)
Re: EME-DXPEDITION
« Ответ #375 : 06 Мая 2016, 11:40:47 »
D44TVD
Hermann DL2NUD asked me to post this information for him.
Hermann is very sorry to announce that he will NOT be QRV 3cm. Due to
performance problems of the used antenna system (mainly lack of suited horn)
he had to make the decision not to take the 3cm equipment with him.
Now the good news: Hermann plans to be QRV as follows
11. May if all goes well he should become QRV before his MS,
he will be on 5760.100
12. May 5760.100 from MR to MS
13. May 2320.100 from MR to MS, 2304 on request (HB9Q
eme-logger)
14. / 15. May 1296.100 from MR to MS
16. May 2320.100 from MR to MS, 2304 on request (HB9Q
eme-logger)
17. May 5760.100 from MR to MS
18. to 23. May he will decide during the activity what band what day,
depending on needs, he will announce on moon-net, mmmonVHF and on HB9Q
logger
Hermann was told that there is good WIFI at his QTH, so communication should
be no problem.
Stay tuned for more information!
Good luck to all working this NEW-ONE!
Vy 73, Dan HB9Q on behalf of Hermann DL2NUD
Оффлайн RA4SD Алексей
  • не член УКВ комитета
Re: EME-DXPEDITION
« Ответ #376 : 11 Мая 2016, 12:56:38 »
EA6/PA2CHR Chris сегодня с 15 UTC продолжит свою ЕМЕ активность по редким квадратам ЕА6.
Подробности, включая лог сработанных ранее станций, тут http://mmmonvhf.de/latest.php?id=4540.
Re: EME-DXPEDITION
« Ответ #377 : 14 Мая 2016, 19:31:44 »
В продолжении информации по работе D44TVD, письмо от HB9Q:
Hi all
Hermann is running a little late with 23cm set-up. He expects to start activity shortly after the moon comes across the hill, probably around 16.30z on 14. May.  He can operate up to 70 dgr of elevation. Then he is QRX until moon is below 70 dgr again. He will be on HB9Q-logger. He is using 1296.100 1st JT65c listening on his echo… so make sure to put your echo on his!
His QTH is HK85FA (not HK84!).
He still has strong wind, not easy to stay on moon.
Good luck all!
Vy 73, Dan HB9Q
Re: EME-DXPEDITION
« Ответ #378 : 15 Мая 2016, 13:29:46 »
Обновление информации по работе D44TVD, письмо от HB9Q
Activity summary for 12./13./14. May
Hermann  did work 3 stations on 6cm. He RXed several more but QSOs were not completed. On 13cm he worked 9 stations and RXed a few more. On 23cm he has worked only 7 stations. It looks like he has a problem on 23cm, he is missing 3-5dBs (RX and TX) compared to the tests from home. He will try to find and fix the problem today before his coming moon-window.
He has at least 20dgr elevation at moonrise and a water-tank in the way shortly after moonrise. He can’t elevate the antenna more than 70dgr. So he is QRX when moon goes higher and comes back when it is again 70 and less.
He has internet, which most of the time works… but some hours he had none. If he can he is on the HB9Q loggers.
His QTH is HK85FA (not HK84!). He has strong winds most of the time, makes it difficult to “stay on the moon”.
His QRGs are 1296.100 JT65c 1st, 2320.100 JT65c 1st (with RX 2304.100 on request) and 5760.100 JT4F 1st.
On 23 and 13cm he RX on his echo, so please make sure you call him +- his echo.
On 6cm during his next activity (18. May) he will TX 100 and RX 100 with no Doppler-control. The callers are asked to do  Doppler-control if they can.
The coming activity days plans are as follows:
15. May 1296.100 1st JT65c
16. May 1296.100 1st JT65c (this is new)
17. May 2320.100 1st JT65c (this is new)
18. May 5760.100 1st JT4F (this is new)
19. to 23. May will be decided later and communicated on moon-net and mmmonvhf.
Good luck all!
Vy 73, Dan HB9Q
Re: EME-DXPEDITION
« Ответ #379 : 18 Мая 2016, 08:30:15 »
Какие уроки можно извлечь из экспедиции?  У меня опыт работы  JT65 не большой, нет еще и года, но Вас, "старожилы", не удивляет  феноменальные результат работы экспедиции? Думаю, что не они первые применили МАР-65 и кросс-Яги в экспедиции и уж точно много людей стационарно используют такую технологию и показывают отличные и выдающиеся результаты. Кросс-Яги-это прорыв!, но что нового в экспедиции-это передача сразу в вертикале и горизонте. Хорошо, но как объяснить  их прием? Результат явно выходит за рамки моих впечатлений. Другого объяснения, как отсутствие помех на острове я не нахожу. Скажу еще более прямо-я не раз работал со станциями, у которых кросс-Яги и они слышат хорошо, но......далеко не так. Так в чем секрет? И есть ли он, или это мое субъективное мнение? Хотелось бы услышать мнение собратьев.
« Последнее редактирование: 18 Мая 2016, 09:19:13 от UT9UR, Аркадий »
Re: EME-DXPEDITION
« Ответ #380 : 07 Июня 2016, 11:11:36 »
Охотникам за WAS via EME - экспедиция KB7Q/0 South Dakota EME с 9 по 13 июня
Квадрат DN85gu на 2м и 70см JT65b и KB7Q/0 всегда первый.
144: 2x 9el. Yagis and 800 watts  144.138 MHz
432: 2x 9wl Yagi and 500 watts  432.088 MHz
Подробности http://kb7qgrid.blogspot.ru/2016/05/south-dakota-eme-june-9-13.html
Re: EME-DXPEDITION
« Ответ #381 : 07 Июня 2016, 14:49:44 »
Думаю все дело в электро-магнитной обстановке, нет помех, можно принимать слабые сигналы!
Успехов.
Re: EME-DXPEDITION
« Ответ #382 : 19 Июня 2016, 16:19:22 »
On behalf of Hermann, DL2NUD I'm forwarding this information:
Hermann got the license for Burkina Faso! The flights and accommodation are
booked. From 14. to 24. October 2016 he will be QRV as XT2AFT in IK92 on
144, 432, 1296 and 2320 MHz.
More information later.
Vy 73, Dan HB9Q
Оффлайн RA9YTX Дмитрий
  • QRA: NO01OM
Re: EME-DXPEDITION
« Ответ #383 : 24 Июня 2016, 21:56:44 »
С 19 по 24 июля планируем экспедицию в Монголию.Локатор NN58AO, берег озера Толбо Нуур.
Будем на диапазонах 80-10м, 6м и берем 2х9Н 400вт ЕМЕ. Позывные JT0YPS, JT0YGC&JT0YTX. Будем рады провести ЕМЕ QSO со всеми желающими. Дополнительная информация по частоте будет позже, т.к. возможно отсутствие интернета.
Оффлайн RX1AS Сергей
Re: EME-DXPEDITION
« Ответ #384 : 25 Июня 2016, 00:02:52 »
Приятная новость, буду рад провести с вами QSO.
Re: EME-DXPEDITION
« Ответ #385 : 29 Июня 2016, 15:46:29 »
ЕМЕ экспедиция 6Y5AZ начала свою работу. Лог здесь http://mmmonvhf.de/latest.php?id=4532.
У них были проблемы с сетью (95В вместо 110В), наведение на Луну ручное.
Оффлайн RW1AY
  • QRA: KO68NJ
Re: EME-DXPEDITION
« Ответ #386 : 30 Июня 2016, 11:36:30 »
Сработал сегодня с 6Y5AZ. Похоже антенну с ручным наведением у них болтает ветром. Сигнал то NIL, а через период -15 !!
Re: EME-DXPEDITION
« Ответ #387 : 30 Июня 2016, 14:26:17 »
поздравляю, Владимир! Наблюдал.  "Пираты" написали: "Переключаю поляризацию вертикал-горизонт, поэтому скачки уровня возможны. Ветра нет вообще-полный штиль".
 Я выключил в 9UT, т.к. уезжаю на пару дней. Вызывать не пытался ни разу по причине слабого приема, в лучшем случае -26 и то иногда. Правда, не "сидел на привязи" от восхода до заката и в условиях проблем с ТВ, я не могу вызывать экспедицию, как некоторые. Это плохо, но что поделаешь! Смотрел в программе Moon-Sked поляризацию-отвратительно, у кого Х-поляризация, тот имеет премущество многократно.
Два неприятных эпизода  без комментариев:
1. PA5Y написал, что "..я вижу на своем СДРе, что некоторые нехорошие мальчишки играют в "паровоз".
2. Оператор 6Y5AZ пишет: "...я вижу разных операторов на одной станции. Напишите мне (письмо), я хочу поговорить об этом".
     Скриншот не делал, это не меня касается, цитаты по памяти, но почти дословно, можете мне верить.
Оффлайн RW1AY
  • QRA: KO68NJ
Re: EME-DXPEDITION
« Ответ #388 : 30 Июня 2016, 15:24:32 »
UT9UR Аркадий, это они неправильно делают , так DXы не должны работать. На приём сколько хочешь, а вот передавать то нужно в одной. Кому надо услышат. А я и не заметил этого сообщения от них, думал ветра. Да и  многие писали - что это ,мол, вас так непостоянно слышно.
Re: EME-DXPEDITION
« Ответ #389 : 30 Июня 2016, 15:57:46 »
Не раз хочется "прикрутить" какую-то "писалку" чата(ов). А так уехала страница и тю-тю.
 Я думаю, что они ("Пираты", 6Y5AZ ) поступают для максимальной пропускной способности, ну, может и ошибаются. Р40МВ задали планку в этом смысле очень высоко, как и в плане приема слабых станций (мне понравилось выражение одного корифея ЕМЕ -"малый пистолет". Очевидно, как противоположность "биг ган", хи!). Они сообщили так же, что наверное разошлют ЩСЛ-карточки за наблюдения. Но все-таки, слышу я слабо. По прежнему без МШУ и Солнце не лучше 3ДБ, это плохо. На старых DJ9BV-14, с МШУ я принимал   6-6,5 ДБ (а с воздушными линиями в четверке еще лучше). На помехи все жалуются, но действительно, найти тихое место затруднительно, а вечером и в выходные-невозможно.
Это писал Спирос.
   Ну, до вечера, поехал я далее. Смотрю, что уже есть интернет-зависимость, тянет на портал за новостями. Анекдот: "Кто не уплатит коммуналку до 25го-отключим интерет!".
