Автор Тема: N8S EME info from UA6LV  (Прочитано 6607 раз)
« : 13 Апреля 2007, 06:05:07 »
Не подписан на satvhf но знаю о наших любителях EME , просьба
переслать туда .
Вот что пишут американцы :
HELLO VLAD !
PLEASE SEND CONGRATULATIONS TO THE BOYS AT N8S FOR A GOOD JOB ON 2M AT THEIR MOONRISE!
3 2M EME QSO'S TODAY:
KB8RQ AT 1347 UTC
W5UN AT 1358 UTC
K6MYC AT 1420 UTC
THEY PROBABLY COULD HAVE MADE MORE QSO'S BUT THEY MADE A FEW ERRORS WITH JT65B.
LET ME EXPLAIN.
WHEN THEY DECODE A CALL SIGN CALLING THEM: "N8S KB8RQ" ETC. THEY SHOULD RETURN WITH
KB8RQ N8S OOO
THEN THEY WILL RECEIVE "RO"
THEY SHOULD NOT SEND "RO"
THEY SHOULD SEND "RRR"
THEN THEY WILL RECEIVE "73"
THEN THEY SHOULD SEND "73" AND QSO IS COMPLETE.  (SOMETIMES THE DX STATION DOES NOT EVEN SEND
"73" AS THE "RRR" IS ENOUGH). WE ALL LIKE TO SEE THE "73" HOWEVER.
THE ABOVE IS THE CORRECT PROTOCAL AND TAKES JUST 6 MINUTES TO COMPLETE A QSO.  NOTE THE TIME
BETWEEN THE 3 QSO'S ABOVE.
NEXT: ON THE "SETUP" ON THE TOP OF THE JT65 SCREEN, CLICK ON "SETUP" AND THEN CLICK ON
"OPTIONS"
HAVE THEM PUT THEIR CALL SIGN AND THEIR GRID SQUARE IN THE BOX THAT APPEARS..  THIS WILL ALLOW
THEM TO CLICK ON
"GenStdMsgs" BOX AND USE THE STANDARD MESSAGE FORMAT.  THIS GIVES THE COMPUTERS MORE INFO TO
WORK ON AND BUYS ABOUT 3 DB ON WEAK RX SIGS.
TELL THEM ALSO THEY CAN CLICK TO A DIFFERENT MESSAGE IN THE "TX" BOXES ANYTIME DURING THEIR TX
OR RX PERIODS.  THIS WILL SAVE TIME ALSO.
TELL THEM THEIR  TIME WAS SLOW BY ABOUT 2 SECONDS AND THAT COSTS US A BIT OF TIME TO ADJUST ON
OUR END FOR THIS ERROR.   WE CAN FIX IT  BUT IF TIME IS OFF, WE CAN'T ALWAYS DECODE RELIABLY AND
QUICKLY
AGAIN, REMIND THEM THEY CAN DECODE SEVERAL CALL SIGNS DURING THEIR "TX" PERIOD. WHEN THEY
DECODE A CALL SIGN, THEY CAN DOUBLE CLICK ON IT AND IT WILL AUTOMATICALLY GO INTO "TX1" AND
"TX2" MESSAGE BOXES.  THEY SHOULD THEN CLICK ON "TX2" SO THEY SEND "KB8RQ N8S OOO" DURING THEIR
NEXT "TX" PERIOD. WHEN THEY GET CALLS SIGNS, ALWAYS SEND CALLS BACK ALONG WITH THE OOO REPORT TO
SAVE TIME. DOING THIS THEY CAN MAKE A COMPLETE QSO IN 5-6 MINUTES.  THEY SHOULD JUST KEEP TRACK
OF ALL DECODED CALLS AND MAKE A QSO ONE AT A TIME.
THANK YOU FOR YOUR HELP AND PLEASE TELL THE N8S BOYS THANKS FROM THE EME AMATEURS!
WISH THEM GOOD LUCK WITH THE EU STATIONS ON THEIR MOON SET!
WE HOPE TO SEE THEM ON 6M EME TOMORROW AT THEIR MOONRISE.  WE HOPE THEY CAN ALSO BE ON 2M EME
AS MANY STATIONS WILL BE CALLING THEM NOW THAT THEY HAD SUCCESS!
I CHAT WITH N8S BOYS DAILY DURING SLOW PERIODS.  PLEASE TELL ALL N8S BOYS TO TRY TO HAVE 2M AND
6M INFORMATION SO WE CAN KNOW WHAT IS GOING ON.  I THINK HRANE YT1AD SHOULD KNOW THAT IT IS
EXTREMEMLY IMPORTANT FOR US TO KNOW WHAT BAND THEY WILL BE ON AND ANY OTHER CHANGES THAT WILL
AFFECT THESE DIFFICULT QSO'S.
I WAS CHATTING WITH N8S BOYS ONE 75 SSB AND 40M SSB THIS MORNING AS THESE QSO'S WERE GOING ON
BUT THEY KNEW NOTHING ABOUT WHAT BAND WAS EVEN ACTIVE.  THIS INFORMATION WOULD BE VERY HELPFUL
SINCE THE SIGNALS ON EME CANNOT BE HEARD, MOSTLY ONLY SEEN ON THE SCREEN AND DECODED ON THE
COMPUTER SCREEN.  PERHAPS THE TEAM LEADERS CAN INFORM EACH OPERATOR OF AT LEAST WHAT BAND THEY
WILL BE USING.  MANY BOYS WERE CALLING THEM TODAY ON 6M EME BUT I THINK THEY WERE NOT ON 6M AT
THEIR MOONRISE.
I WILL CHECK WITH N8S BOY LATE IN MY DAY HERE TO SEE IF WE CAN FIND OUT WHAT BAND (S) 2M AND OR
6M THEY WILL BE ON AT THEIR MOONRISE TOMORROW.
ONE MORE THING.  SOME EME BOYS CANNOT BE ON TILL SATURDAY AND SUNDAY MORNING.  PLEASE ASK THE
TEAM LEADERS TO ALLOW THE 6M AND, IF POSSIBLE, THE 2M EME STATIONS TO OPERATE ON SUNDAY MORNING
MOONRISE.
THE SUNDAY MOONRISE IS ABOUT 1 HOUR BEFORE SUNRISE SO THEY STILL SHOULD HAVE PLENTY OF TIME FOR
TEAR DOWN STARTING JUST AS EARLY AS 1 HOUR AFTER SUN RISE.  THANK YOU.
PLEASE RESPOND TO ME BY EMAIL IF YOU DO GET THIS MESSAGE THROUGH TO THE N8S BOYS.
THANKS FOR YOUR TIME AND EFFORT!
73, MIKE K6MYC.
Best regards,
Vlad/UA6LV                          mailto: ua6lv@dx.ru or ua6lv@mail.ru
Оффлайн RA3AQ
  • QRA: KO85sp
Отв:N8S EME info from UA6LV
« Ответ #1 : 14 Апреля 2007, 06:52:08 »
Последняя возможность сработать N8S - в воскресенье на заходе  луны у них. Идут громко до -22
73 de RA3AQ
RA6DA
« Ответ #2 : 15 Апреля 2007, 07:25:13 »
Да, жаль, что парни абсолютно к ЕМЕ не готовились, у многих надежды рухнули. Моё QSO с ними сегодня длилось пол-часа. Они так и не освоили процедуру. На последних минутах перед их moonset успел сработать Виктор, UA9YLU. Сигнал был с хорошим уровнем, до -23.
Оффлайн RA3AQ
  • QRA: KO85sp
« Ответ #3 : 16 Апреля 2007, 11:00:36 »
Поправил скрипт для поиска по логу, т.к. на родном сайте он с ошибкой. Но пока лог пустой - http://www.vhfdx.ru/logsearch_n8s.php
Post edited by: ra3aq, at: 2007/04/16 12:02
73 de RA3AQ
RA6DA
« Ответ #4 : 16 Апреля 2007, 11:56:50 »
Дима, не работает. qso RN6BN, RA6AX уже есть у них в логе. Я вот здесь смотрел, не глючит: http://logsearch.de/index.php?option=com_content&task=view&id=175&Itemid=106
но нас пока нету.
Оффлайн RA3AQ
  • QRA: KO85sp
« Ответ #5 : 16 Апреля 2007, 12:19:01 »
Спасибо, посмотрел. Тогда уж сюда - http://dxped.com/n8s-logs.php
73 de RA3AQ
RA6DA
« Ответ #6 : 16 Апреля 2007, 12:58:19 »
Спасибо. По этой ссылке я следил за логом во время экспедиции. Другие глючили. Теперь в списке online logs N8S не нахожу. Дима, есть ли уже инфо, с 5W они будут ЕМЕ?
