Автор Тема: Полезные EME ссылки  (Прочитано 131900 раз)
Re: Полезные EME ссылки
« Ответ #75 : 24 Августа 2019, 20:02:11 »
2,5 m offset dish
OK1DFC Зденек пишет:
Большие антенны уходят в прошлое...
...антенна для экспериментов EME MW уже вращается как в AZ, так и в EL.
Надеюсь, что все будет сделано, и буду готов к ARRL Microwave Contest, который состоится в выходные 21 и 22 сентября 2019 года.
« Ответ #76 : 13 Сентября 2019, 15:24:46 »
The EME Newsletter collection
Contents of chapter 1 (transmitters)
Contents of chapter 2 (receivers)
Contents of chapter 3 (antennas)
Contents of chapter 4 (miscellaneous)
(содержание разделов в TXT файлах)
Preface - Предисловие (- Перевод -)
There is no doubt that there is a continuing increase in the number of radio amateurs operating on the VHF, UHF and SHF bands who become interested in using the moon as a passive reflector of radio signals. If we look; back in the evolution of Earth Moon Earth communication, it is true to say that the equipment involved with this type of communication was much more complex than the typical VHF equipment commercially available and therefore beyond the reach of many radio amateurs. ‘ Compared to the equipment used back in 1960, when the first amateur EME contacts were made, the techniques used today are greatly enhanced. Browsing through the index, we see computer controlled antennas, cooled GaAaFet preamps, new power amplifier techniques, computer optimised dishes and yagi’s and a lot more. Thanks to the support of all the active EME amateurs, Alan Katz K2UYH could publish and distribute The 432 and Above EME Newsletter containing everybodies experiences on the EME frontier. New techniques and experiences from EME amateurs created the possibility for more amateurs to join into EME. This is our first attempt to collect the information and experiences available through the Newsletters and to collate it into a book. The reader will get an impression of the evolution of the techniques involved in EME. We achieved this by representing the articles in the same order as they appeared in the Newsletter. This may have resulted in a somewhat strange layout of the book, but we felt the idea of time most valuable. We tried to keep as much aa possible to the original articles published in the Newsletter, although this was sometimes hard to achieve, as a lot of articles were not more than just a little remark or sketch. One should be aware that the possibility exists that we missed publications of articles, but gathering all the information from 15 years of EME-Newsletter was a difficult task. We hope that this book will encourage more design, constructional and EME activity. Share your results, your knowledge and your ideas with fellow amateurs and let the future be an interesting one, trying out new techniques. Note that this book is originally written for amateur use only. The information in this book is not guaranteed to be correct. However if you have any comments on errors, additions or other matters, we advise you to contact the original author of the article.
Geert Stams PA3CSG Peter Beyer PA3AEF
« Ответ #77 : 01 Октября 2019, 19:24:58 »
Test 23cm EME with dish 30m
Adrian LU1CGB информирует о возможностях тестирования 30м параболы на 23cm  EME
Hello
With a group of enthusiastic hams and the local people in the IAR (Instituto Argentino de Radioastronomia) well have a test window next week end for RX only in 23 cm with a 30 meter antenna near Buenos Aires. Starting TX around 21:30 hs to IAR to test for 1 hour, to check if we can track the antenna properly aimed to the Moon and RX chain, if someone wants to try, we will be coordinating in HB9Q chat and post some results.
Any help will be appreciated.
73, Adrian LU1CGB
Привет
С группой энтузиастов-радиолюбителей и местных жителей в IAR (Instituto Argentino de Radioastronomia) у нас есть тестовое окно на следующей неделе для RX только в 23 см с 30-метровой антенной около Буэнос-Айреса. Начиная передачу около 21:30 часов в IAR, чтобы проверить в течение 1 часа, чтобы проверить, можем ли мы правильно отследить антенну, нацеленную на цепь Луны и RX, если кто-то захочет попробовать, мы будем координировать в чате HB9Q и опубликовать некоторые результаты.
Любая помощь будет оценена.
73, Адриан LU1CGB
« Ответ #78 : 05 Октября 2019, 00:25:00 »
Немного экзотики ;-) - Project BIG-DISH 2007 - A Moon Bounce Experiment With A 32m KDDI CassegrainWith Antenna - A Special Station 8N1EME
...(EME Conference 2008)
« Ответ #79 : 05 Октября 2019, 09:15:39 »
Интересно было посмотреть скрины пайлапов "с той стороны" - стр. 101-105
На 144 ввиду компромисса 32-х метровая тарелка работала как десятиметровая.
Оффлайн RW3PX
  • Юрий.
« Ответ #80 : 05 Октября 2019, 09:35:04 »
...Special Station 8N1EME
Помню связь с ними на 432МГц. Посмотрел в журнале рапортА - "оскары", так было принято при первом QSO. Но реально проходили на с RST 569 (на слух),не сказать что бы очень громко для такой "махины". Моё эхо было примерно таким же,использовал тогда 8х15эл., расположенных кривым эллипсом,т.е. 2х4 вертикально и по сторонам,ниже симметрии, по две вертикально. Да....были времена,настоящие времена!
ex : UW3PX,UA3PDB, RA3PDB.
Оффлайн RW3PX
  • Юрий.
« Ответ #81 : 05 Октября 2019, 11:10:29 »
...использовал тогда 8х15эл...
Совсем плохой стал, использовал  12х15эл.
« Последнее редактирование: 05 Октября 2019, 11:13:36 от RW3PX »
Оффлайн UR5MY
  • QRA: KO90db
« Ответ #82 : 06 Октября 2019, 07:09:31 »
Да, вот это ребята серьёзно повёрнутые, 8N1EME- сколько пошло денег и труда...хотя как сказать, в отличии от тех, кто ничем не увлекается, люди живут не зря-у них есть мечта, есть цель и есть результаты и неплохие, чего только стоят пайлапы.  :D
« Ответ #83 : 13 Октября 2019, 11:45:29 »
+ если вы можете прислать мне данные измерений шумов Солнца, это было бы неплохо,
73 & best regards!
Matej, OK1TEH
10 october 2019 - обновлена таблица  The Sun Noise measurements [432 MHz - UP]
Vy Tnx ALL!
« Ответ #84 : 13 Октября 2019, 14:09:03 »
Очень интересная статистика - Matej просто молодец, хорошо всё систематизировал. Познавательна графа Delta. Если "плюс" - понятно, погрешность измерений. Если "минус" - есть причины, которые невозможно учесть в калькуляторе VK3UM, например помехи. Интересно, что сам VK3UM в "минусе" на двух диапазонах. Таблица с "математикой" и тем, у кого не хватает данных - выдает фантастические цифры.
« Ответ #85 : 14 Октября 2019, 10:17:24 »
Мысли об отрицательном значении Delta:
возможно это следствие экранирования облучателем и штангами поддержки, а также переизлучение ими внешних шумов. Не думаю, чтобы тот же VK3UM имел такую большую погрешность измерений.
Здесь думаю самый точный способ измерений - анализатор после МШУ. В моём случае (за неимением анализатора) аттенюатор от Х1-42, шаг 1дб, а десятые уж с помощью NoiseMeter. Аттенюатор надо согласовать хотя бы шестидецибельниками, значит нужен второй МШУ.
ps Здесь тоже соревнование: у кого лучше и точнее - ведь "туфту" не напишешь, т.к. всё видно по работе на Луне.
« Ответ #86 : 15 Октября 2019, 11:03:39 »
в копилку
EME Советы... - EME Hints... - VE2ZAZ
« Ответ #87 : 16 Октября 2019, 23:06:02 »
Сравнение QRA64 и JT4 для 10 ГГц EME - перевод вольный ;-)
Рекс Монкур, VK7MO и Чарли Саклинг, G3WDG
     Аннотация
 Наши результаты показывают, что для 10 ГГц EME (разнесение 50 Гц) QRA64 имеет преимущество перед JT4, которое варьируется от примерно 1,5 дБ при работе в режиме ожидания до примерно 4 дБ при работе с неизвестной или случайной станцией. Другие привлекательные особенности QRA64 заключаются в том, что он не использует файл базы данных позывного и практически не подвержен ложному декодированию.
     Введение
 JT4F широко использовался для EME 10 и 24 ГГц, уже на протяжении многих лет, и с очень хорошими результатами. В 2016 году Нико Палермо, IV3NWV, разработал встроенную структуру нового цифрового режима, получившего название QRA64 (1). Режим был усовершенствован и реализован в WSJT-X Нико и Джо Тейлором, K1JT (2). Первоначальная работа Нико и Джо была направлена ??на VHF EME, где QRA64 превзошел JT65. В июле 2016 года мы провели эфирные тесты, чтобы выяснить, не приведет ли улучшенная производительность к  возможности использования режима на микроволнах ...10 ГГц, когда либрационное "размытие" сигнала намного шире, чем расстояние между тонами. После наших первоначальных испытаний, которые показали аналогичную производительность с JT4, Нико улучшил декодер, чтобы справиться с более высоким уровнем "размытия" сигнала при EME на микроволновых диапазонах. Результаты, о которых мы сообщаем, относятся к этому улучшенному декодеру, реализованному в WSJT-X r7609 или более поздней версии.
 Короткое лунное окно между нами ограничивало время для тестирования, и поэтому мы применили метод симуляции, используя образцы сигналов встроенных в пакет WSJT-X, чтобы иметь возможность сравнивать режимы. Моделирование (симуляция) позволяет использовать гораздо большее количество тестовых циклов, чтобы преодолеть статистическую неопределенность, существующую при гораздо меньшем времени выборки при эфирных испытаниях.
 Были некоторые ограничения в точности образцов сигналов, доступных в начале этой работы, и K1JT внес изменения в алгоритмы расширения сигнала в симуляторе QRA, чтобы симуляция соответствовала нашим экспериментальным измерениям форм сигналов с высокой степенью точности. , Алгоритмы в симуляторе JT4 были позже изменены, чтобы быть идентичными тем, которые использовались в симуляторе QRA64. Теперь модифицированные тренажеры можно было использовать с уверенностью.
     QRA64 и JT4
 QRA64 не использует базу данных Call3.txt (как это делает JT4 при использовании глубокого поиска), но вместо этого использует информацию, полученную в результате предыдущих успешных декодирований, по мере продолжения QSO. Например, поскольку мы знаем свой собственный позывной, это может быть использовано для улучшения декодирования сообщения, направленного нам, и дальнейшее улучшение может быть получено после того, как мы декодировали позывной другой станции.
     Метод моделирования
 Либрационное "размытие" сигнала (которое может составлять до 200 Гц или более при 10 ГГц) возникает из-за различных доплеровских явлений, возникающих при отражениях от поверхности Луны, и увеличивается пропорционально частоте. Кроме того, форма "размытия" изменяется с частотой, так, что на VHF/UHF-спектре "размытие" имеет тенденцию иметь узкий центральный пик, из-за зеркального отражения, потому что VHF/UHF "видит" Луну, как относительно гладкую поверхность. На более короткой длине волны 10 ГГц Луна выглядит шероховатой и дает более рассеянное отражение с отраженной энергией, распределенной более равномерно по поверхности Луны. Соответственно, необходимо применить алгоритм "размытия" сигнала, который относится к длине волны, которую мы пытаемся смоделировать. На графике 1 показан пример производительности симулятора по сравнению с эфирными измерениями с одним тоном.
***График 1: Форма имитатора и результаты в эфире, полученные между G3WDG (3-метровая антенна) и LX1DB (3-метровая антенна) с разбросом 154 Гц.
Наши моделирования основаны на 1000 тестах с шагом 0,5 дБ и линейной интерполяцией между уровнями дБ для определения уровня декодирования 50%. По нашим оценкам, при использовании 1000 тестов результат будет хорошим до 0,1 дБ.
     Улучшение производительности QRA64 по сравнению с JT4
 Оба режима сравнивались с моделируемым расширением 50 Гц на частоте 10 ГГц. Производительность QRA64 детально сравнивается с JT4f в Приложении
(рис. Activity)  ниже.
     Результаты моделирования в диапазоне либрационного "размытия" сигнала.
 На графике 2 показаны результаты для различных субмод QRA64 по сравнению с JT4f, и он основан на передаче двух позывных и рапорта с глубоким поиском, примененным к JT4f, и предшествующего знания обоих позывных, примененных к QRA (то есть ситуации sked). В обоих случаях позывные известны, а рапорт неизвестен, поэтому результаты сопоставимы.
***График 2: Имитационное сравнение субмод QRA64 с JT4f с "размытием" сигнала на 10 ГГц
Видно, что в диапазоне от 20 до 50 Гц лучший подрежим QRA64 сохраняет преимущество около 1 дБ перед JT4f. При бОльшем размытии сигнала преимущество QRA64 уменьшается до нуля, при размытии около 240 Гц. Тем не менее, следует отметить, что при меньшем размытии более широкие субмоды QRA64, такие как E, имеют тенденцию не улучшаться, и, таким образом, одним недостатком QRA64 является то, что вам необходимо заранее выбрать оптимальную субмоду, и это ограничивает его использование для случайных QSO на предельных уровнях сигнала, где либрационное размытие не может быть определено заранее. (Это ограничение может быть преодолено в будущих версиях).
     Сравнение в эфире
 В качестве проверки производительности симуляторов мы провели эфирное тестирование, передавая QRA64 и JT4 в разные периоды времени для сравнения результатов. Для этих тестов мощность была уменьшена до точки, в которой оба режима достигли только предельных декодирований, а затем было выполнено сравнение путем применения дополнительной функции шума WSJT-X для точной настройки предела декодирования.
На графике 3 приведены результаты сравнений в эфире в логарифмическом масштабе. Каждая точка представляет собой тест во время прохождения Луны и основана на анализе обычно 10 периодов в каждом режиме в моменты времени, когда обе станции имеют четкое представление о Луне.
Отмечено, что средние результаты в эфире немного выше, чем смоделированные результаты, что позволяет предположить, что QRA64 в диапазоне от 20 до 50 Гц имеет преимущество около 1,5 дБ.
***График 3: Сравнение QRA64 и JT4 в эфире со ссылкой на результаты моделирования
     Использование предварительных данных для помощи в проведении QSO
 Определение QSO в VHF было формализовано еще в 1957 году Тилтоном в QST (3). Тилтон сделал важное различие между «идентификацией» обоих позывных и обменом неизвестной «информацией», такой как рапорт. В этом отношении Тилтон принял во внимание тот факт, что sked, где известны оба позывных, является законным QSO, но кроме того, необходимо обменяться неизвестной информацией (такой как рапорт). Важной проблемой является то, что при «идентификации» известного позывного это должно быть идентифицировано по радиоканалу, а не ложное декодирование от шума (эта проблема возникает во всех режимах при работе sked). Соответственно, ищется низкая вероятность ложных декодирований при «идентификации» известных позывных.
     Ложные декодирования
 JT4 действительно страдает от случайных ложных декодирований, но почти все они могут быть отклонены опытным оператором, принимая во внимание такие факторы, как согласованность позывных или ожидание второго декодирования, когда указанные уровни достоверности являются низкими.
Ложные декодирования происходят и в QRA64, но они крайне редки. Даже при выполнении 10 000 имитационных тестов с маргинальными сигналами и изменении позывных, отправляемых одним письмом, мы не увидели одного ложного ложного декодирования с вашим собственным позывным. Мы рассматриваем это как существенное преимущество QRA64.
     Нахождение очень слабых сигналов
 В отличие от JT65 и QRA64, и JT4 не используют систему синхронизации одного тона, которую можно легко идентифицировать на водопаде. В случае QRA64 программа добавляет красный маркер на водопад в конце каждого периода, чтобы указать, где обнаружена синхронизация. Хотя это полезно, когда сигналы на несколько дБ выше предельных, маркер часто отсутствует на слабом сигнале и иногда отображается на неправильной частоте (в частности, при прослушивании шума). Решение в случае как QRA64, так и JT4 состоит в том, чтобы передать один тон в начале проверки, для определения слабого сигнала. Такие тоны предусмотрены как для JT4, так и для QRA64. Для JT4 и QRA64 используется один и тот же набор одиночных тонов:
1000 Гц = Tune (T)
1250 Гц = Пожалуйста, отправляйте сообщения (M)
1500 Гц = RRR (R)
1750 Гц = 73 (73)
Их можно передавать как в JT4, так и в QRA64, установив флажок Sh, как показано на рис. 1 ниже, и затем выбрав соответствующее окно сообщения TX.
  Тональный сигнал 1250 Гц можно получить, установив флажок TX6 (показанный выше со стрелкой) и выбрав кнопку сообщения Tx6. Кроме того, при ручном вводе @XXXX в любом поле TX будет отправляться один тон с частотой XXXX Гц.
Одиночные тоны должны интерпретироваться оператором - программа не делает этого за вас, и они не распознаются автоматическим секвенсором (если используется). Частоты тонов считываются с водопада. Одиночные тоны хорошо видны на графике линейного среднего среднего желтого до -30 дБ с расширением 50 Гц и отправка однотонального RRR имеет преимущество более 4 дБ по сравнению с отправкой позывных и RRR как обычного сообщения. Пример показан на рисунке 2, который показывает 1000 Гц (или T-тон)
     Averaging (Усреднение)
 В настоящее время QRA64 не имеет средства усреднения, такого как JT4f, которое может получить до 2 дБ, если есть время для усреднения за несколько периодов. Существует возможность добавить усреднение к QRA64 и получить дальнейшее улучшение.
     Выводы
 QRA64 не использует файл Call3.txt и имеет значительное преимущество около 4 дБ при работе со случайной станцией, не включенной в файл Call3.txt.
В то время как QRA64 имеет относительно небольшое преимущество - около 1,5 дБ по сравнению с JT4f при работе в режиме sked, где известны оба позывных, каждый дБ считается при работе с предельными сигналами EME.
Привлекательной особенностью QRA64 является тот факт, что он практически не подвержен ложному декодированию, и поэтому в целом мы рекомендуем QRA64 для слабого сигнала 10 ГГц EME.
      Acknowledgements ;-)
Nico Palermo, IV3NWV, and Joe Taylor, K1JT, for designing the QRA mode and implementing it in WSJT-X.  K1JT  for implementing simulators in WSJT-X.  Also thanks Joe and Nico for reviewing this paper and providing many useful suggestions.
     Приложения:
(1)   Nico Palermo, IV3NWV: EME-2016-IV3NWV-Presentation
(2} Joe Taylor, K1JT, "WSJT-X: New Codes, Modes, and Tools for Weak-Signal Communication" (PowerPoint Slides: 17th International EME Conference, Venice, August 2016)
(3) Tilton E. P W1HDQ " The World above 50 Mc" QST, March 1957
(4) A Power Point presentation relating to this paper is at:  https://tinyurl.com/ya6484wv
« Последнее редактирование: 16 Октября 2019, 23:29:21 от Михалыч »
« Ответ #88 : 17 Октября 2019, 13:40:42 »
2019 сентябрь/октябрь - 432 AND ABOVE EME NEWS September/October 2019 VOL 48 #9
15. 10. - 17. 10. 2019  в Пардубице (Чехия) проводится 29-я конференция по радиосвязи
интересная лекция Mirek OK2AQ не тему „Rádiové komunikaci s kosmickými sondami“ - «Радиосвязь с космическими зондами»
« Последнее редактирование: 17 Октября 2019, 13:49:39 от Михалыч »
« Ответ #89 : 23 Октября 2019, 16:52:55 »
Michael and moon - Луна и Майкл (Фарадей)....
и ещё немного, о Faraday Rotation - вращении Фарадея...
(транслит на русский яз., можно выбрать в левом верхнем углу страницы)
