Автор Тема: Полезные EME ссылки  (Прочитано 139370 раз)
Re: Полезные EME ссылки
« Ответ #360 : 31 Июля 2025, 16:16:55 »
 - EME Observer - 10GHz EME stations map, one-click sked planner, moon data & station statistics      Dear fellow moonbouncers,
Several months ago, I developed a web application to support my portable 10 GHz EME work. After testing and dozens of successful 3 cm QSOs, including some with spatial polarization offset tracking, I have now made the tool publicly available. I hope it might be useful to at least a few others in the community as well.
EME Observer: https://dxer.site/eme-observer/
User Guide: https://dxer.site/eme-observer/user-guide.html
Key Features
    Interactive map of known 10 GHz EME stations (active, DXpeditions, and SKs). Clicking a marker reveals station details
    Geocentric Moon data: footprint, distance, declination, and additional path loss relative to loss at perigee (30-minute intervals)
    Topocentric data for both Station Locator and DX Locator:
    - Moon azimuth and elevation
    - Moonrise and moonset times
    - Libration rate
    - Doppler spread (equivalent to Width in WSJT-X)
    One-click Sked planner shows common Moon windows between stations, with:
    - Combined libration rate
    - Combined Doppler spread (DXWid in WSJT-X)
    - Spatial polarization offset (Dpol in WSJT-X)
All calculations are accurate to better than 1 arcminute (0.017°). While designed for 10 GHz, most metrics (except Doppler spread, which is calculated for 10.368GHz, and some libration effects) are relevant across other EME bands.
Also included:
    Antenna, power, and DXCC statistics
    Filterable table of active and SK 10 GHz EME stations
Note: This is not a link budget calculator. It assumes you can interpret the data for your specific setup.
Station data can be added or modified using the “Add Station” button.
Special thanks to Jan PA0PLY for testing the application and for maintaining the excellent 432 and up EME station lists, which were invaluable for validating the data used in EME Observer.
Attached is a collage showing various views and charts from the application.
73 es DX,
Max SA5IKN    -------------------------                    Несколько месяцев назад я разработал веб-приложение для поддержки моей портативной EME-работы на 10 ГГц. После тестирования и десятков успешных QSO на 3 см, в том числе с отслеживанием пространственного смещения поляризации, я сделал инструмент общедоступным. Надеюсь, он будет полезен хотя бы нескольким другим членам сообщества. Основные функции Интерактивная карта известных EME-станций на 10 ГГц (активных, DX-экспедиций и SK). При нажатии на маркер открывается информация о станции. Геоцентрические данные о Луне: область обзора, расстояние, склонение и дополнительные потери на траектории относительно потерь в перигее (с 30-минутным интервалом). Топоцентрические данные для локатора станций и локатора DX: - Азимут и высота Луны Время восхода и захода Луны Скорость либрации Доплеровское расширение (эквивалентно ширине в WSJT-X). Планировщик Sked одним щелчком мыши показывает общие окна наблюдения за Луной между станциями, включая: Комбинированную скорость либрации Комбинированное доплеровское расширение (DXWid в WSJT-X) Пространственное смещение поляризации (Dpol в WSJT-X). Все расчеты имеют точность менее 1 угловой минуты (0,017°). Хотя данные разработаны для частоты 10 ГГц, большинство показателей (за исключением доплеровского расширения, которое рассчитывается для частоты 10,368 ГГц, и некоторых эффектов либрации) актуальны и для других диапазонов EME. Также включены: Статистика антенны, мощности и DXCC Фильтрируемая таблица активных и SK 10 ГГц EME станций Примечание: Это не калькулятор бюджета линии связи. Предполагается, что вы можете интерпретировать данные для вашей конкретной конфигурации. Данные о станциях можно добавлять или изменять с помощью кнопки «Добавить станцию». Особая благодарность Яну PA0PLY за тестирование приложения и поддержку отличных списков EME станций 432 и выше, которые были бесценны для проверки данных, используемых в EME Observer. Прилагается коллаж с различными видами  и диаграммами из приложения. 73 es DX, Макс SA5IKN
« Последнее редактирование: 31 Июля 2025, 16:18:58 от Михалыч »
« Ответ #361 : 29 Августа 2025, 07:31:50 »
432 AND ABOVE EME NEWS AUGUST 2025 Volume 54 Number 8
Web Page2025-08 Vol 54-08
PDF2025-08 Vol 54-08
  + pdf в SHF GROUP
« Ответ #362 : 29 Августа 2025, 15:45:57 »
« Ответ #363 : 16 Сентября 2025, 11:57:00 »
Hi Lunatics,
I will upload the latest version of the EME database around September 15th.
Please let me know any furhter updates for your station by using the reply form on my website
br. Jan, PAoPLY  https://www.pa0ply.nl/eme-directory/
« Ответ #365 : 22 Сентября 2025, 18:30:00 »
 - Kostenlose Simulationen von Strahler und Reflektor für höchste Performance   (OE2IGL 15.02.2025) - Antenna and Feed simulation
« Ответ #366 : 29 Сентября 2025, 13:47:35 »
432 AND ABOVE EME NEWS September 2025 Volume 54 Number 9
Web Page    2025-09 Vol 54-09
PDF    2025-09 Vol 54-09
  + pdf в SHF GROUP  и  УКВ ПОРТАЛ РОССИЯ раздел EME связи через Луну
« Ответ #367 : 05 Октября 2025, 13:24:21 »
KA1GT - 23cm Radio Sky Temperature
На нижних диапазонах EME, 6 м, 2 м и 70 см, эффективная температура неба может быть очень высокой, что приводит к высокому уровню шума неба, который, в свою очередь, затрудняет обнаружение и декодирование слабых сигналов. На 23 см большая часть этого фонового радиошума, но не весь, отсутствует.
Повсюду на небе есть шум. Это реликтовое излучение (CMB), или реликтовое излучение (Cosmic Microwave Background). Это смещенный в красную область радиошум, оставшийся от Большого взрыва, возникшего в результате зарождения нашей Вселенной, который, по-видимому, произошел около 14 миллиардов лет назад. Существует также фоновый шум, в основном от галактических источников, например, состоящий из шума от звезд, газовых облаков и других космических источников. Этот шум в основном ограничен областью неба, где мы видим Млечный Путь, как на карте неба ниже.
Шум неба можно измерить с помощью шумовой температуры. По сути, это эквивалентная температура резистора, который будет создавать ту же мощность шума, что и антенна. Самая низкая шумовая температура неба находится в районе 2,7 К (2,7 градуса выше абсолютного нуля). Антенна действует как источник шума, равный шумовой температуре объекта, на который она направлена. Таким образом, наведение идеальной антенны на небо с температурой 2,7 К приведет к шумовой температуре антенны 2,7 К. Идеальная антенна не будет иметь потерь и боковых лепестков, так что это, очевидно, теоретическая ситуация! Аналогично, антенна, направленная на землю в день с температурой 0°C (273 К), будет иметь шумовую температуру 273 К. Это разница примерно в 20 дБ. Таким образом, если бы у вас была идеальная система приёма без потерь и малошумящий усилитель с коэффициентом шума 0 дБ, вы бы увидели разницу в мощности шума примерно в 20 дБ между небом с температурой 2,7 К и землей с температурой 273 К. Даже с лучшей в мире антенной и лучшим в мире криогенным малошумящим усилителем вы не увидите таких высоких значений.
Какова же температура самой холодной области неба на частоте 1296 МГц?
Температура холодного неба около 1300 МГц складывается из нескольких компонентов.
Реликтовое излучение = около 2,7 К Галактический (возможно, с некоторой долей внегалактического) континуума. С помощью ряда методов он определяется примерно на уровне 1 К Атмосферный шум, вызванный молекулярно-атомным поглощением в атмосфере. Эта температура переменна и зависит от погоды и высоты над уровнем моря, но её можно оценить примерно на уровне 1,5 К.
Итак, мы наблюдаем температуру неба в самой холодной части северного неба, далеко от Млечного Пути, около 5,2 К. Она будет расти по мере приближения к Млечному Пути и наблюдения через плоскость галактического диска, особенно при наблюдении в направлении центра Галактики. Здесь температура неба будет зависеть от ширины диаграммы направленности антенны, поскольку «горячая» область неба довольно мала, поэтому чем больше ширина диаграммы направленности, тем ниже средняя температура. При ширине луча по уровню 3 дБ около 5 градусов (типичная для антенны класса 3 м на частоте 1296 МГц) максимальная средняя температура неба, вероятно, составляет порядка 25 К. При ширине луча в 1 градус небо в направлении центра галактики может выглядеть горячим до 100 К на частоте 1296 МГц и более 2500 К на частоте 432 МГц.
Похоже, что непрерывный галактический шум уменьшается в (f1/f2)^(-2,8) раз, где f1 — более высокая частота, а f2 — более низкая. Это позволяет предположить, что непрерывный галактический шум на частоте 1296 МГц составит всего около 4,5% от наблюдаемого на частоте 432 МГц. На частоте 1296 МГц небо относительно спокойно. Уровень шума приёмника системы определяется суммой шума от многих источников. Одна из них — температура антенны, которая представляет собой комбинацию шума неба, шума земли из-за любых перетоков и проникновений, а также шума, улавливаемого боковыми лепестками, которые касаются земли. Кроме того, есть шум МШУ и шум, создаваемый потерями в соединении между МШУ и антенной (обычно это изолирующее реле с соответствующими кабелями и разъемами).  Все эти факторы можно выразить как шумовые температуры. На 23 см коэффициент шума МШУ может составлять 0,25 дБ, что можно выразить как шумовую температуру около 17 К. Потери между входом МШУ и антенной могут составлять 0,05 дБ, что соответствует примерно 3 К. Для типичной сетчатой ​​антенны перетоки и проникновение могут вносить вклад в шум, составляющий от 15 К до 25 К. Таким образом, до добавления температуры шума неба мы, вероятно, уже имеем шумовую температуру около 40 К. Если принять самое холодное небо за 3 К, то шумовая температура системы составит около 43 К. Тогда эта система будет показывать примерно на 8 дБ больше. Шум при наведении антенны на землю (при 0°C) был выше, чем при наведении с неба.
При наблюдении за Луной с помощью антенны с шириной луча, значительно большей, чем у Луны (а это практически все антенны, используемые радиолюбителями на 23 см), антенна будет видеть в основном шум от неба. Хотя Луна также является источником шума, она обычно занимает лишь очень малую часть диаграммы направленности антенны. Даже с антенной диаметром 10 м на 23 см Луна будет занимать лишь около 10% ширины луча по уровню 3 дБ.
Ниже представлена ​​карта температуры неба на частоте 1420 МГц, показывающая только реликтовое излучение и шум континуума (широкополосный шум), без учёта вклада водорода.
Облака (которые не видны на частоте 1296 МГц) и любые другие дискретные источники частот. Это должно быть довольно точной оценкой того, что могла бы увидеть станция EME на 23 см.
Приведённые выше данные из Astrophysical Journal. Белый диск представляет собой диаграмму направленности 5 градусов (~ 3 дБ диаграммы направленности 3-метровой антенны на 23 см).
Цифры обозначают температуру неба в градусах Кельвина. Самая «горячая» часть неба находится в галактической плоскости, которая оптически определяется Млечным Путём на ночном небе. Траектория Луны пересекает эту область. На более длинных волнах шум может быть очень высоким, но на 23 см он, как правило, довольно низок. На большей части неба он менее 10 К, а во многих областях может опускаться до 3–4 К. При этом на 23 см небо, как правило, очень спокойное. Лишь в некоторых областях, например, в созвездиях Лебедя (карта вверху справа) и Стрельца, температура достигает двузначных значений. Самая горячая область — это направление на центр Галактики. Луна пересекает область Стрельца каждый месяц. Это оказывает существенное влияние на работу на диапазонах 6 м, 2 м и 70 см, но не так сильно на 23 см. Фоновый шум на 23 см может увеличиться, возможно, на столько же, на 2 или 3 дБ для больших антенн, что повлияет на декодирование слабого сигнала. Для небольших антенн с большей шириной диаграммы направленности повышение температуры неба меньше, поскольку более горячие области не заполняют диаграмму направленности.
См. Ссылки
Вот несколько соответствующих документов. Следует отметить, что многие измерения в диапазоне L 1400 МГц направлены на поиск излучения H1 (водорода) на частоте 1420,4 МГц (±2 МГц из-за доплеровского сдвига) от облаков водорода, связанных с плоскостью Галактики (Млечный Путь, видимый с Земли). Эта область представляет интерес для радиоастрономов. Некоторые исследования учитывают этот шум, другие — нет. Шум неба на частоте 1296 МГц должен быть очень похож на шум в районе 1400 МГц, если исключить из измерений излучение водорода.               * - Peak sky temperature as a function of beamwidth - NARO
  * - An Absolute Measurement of the Cosmic Microwave Background Radiation Temperature at 20 Centimeters
 * - L-BASS: a project to produce an absolutely calibrated 1.4 GHz sky map I – Scientific rationale and system overview
* - L-BASS: A project to produce an absolutely calibrated 1.4 GHz sky map.    II - Technical Description of the System
« Последнее редактирование: 05 Октября 2025, 13:28:47 от Михалыч »
« Ответ #368 : 05 Октября 2025, 18:07:53 »
Сегодня проверял. На улице 283К, небо/нагрузка 9дб. Небольшая облачность.
« Ответ #369 : 15 Октября 2025, 08:04:30 »
 EME Observer   (см. сообщение нр 360  http://forum.vhfdx.ru/eme-b7/poleznye-eme-ssylki/msg535440/#msg535440), изначально созданный для диапазона 3 см, теперь поддерживает УКВ диапазоны от 70 см и выше:
Благодаря воодушевляющим отзывам станций, использующих EME Observer для планирования QSO на 10 ГГц и отслеживания траектории Луны, инструмент теперь поддерживает все диапазоны от 432 МГц и выше — выберите диапазон на панели управления.   Также был добавлен новый режим отслеживания в реальном времени — спасибо Яну PA0PLY за его внедрение. Просто нажмите кнопку «Отслеживать», чтобы включить его. Теперь вы также можете переключаться между режимами «Активный»/«Все станции», чтобы отображать только активные и скрывать все предыдущие активации — отличное предложение от Зденека OK1DFC, Гая F2CT и Яна PA0PLY.
 EME Observer: https://dxer.site/eme-observer/ Руководство пользователя: https://dxer.site/eme-observer/user-guide.html
Данные о станциях EME Observer любезно предоставлены отличным EME Directory PA0PLY, который Ян с большим энтузиазмом поддерживает уже много лет. Пожалуйста, проверьте актуальность информации о вашей станции и отправьте любые обновления Яну PA0PLY. Если вы хотите добавить изображение своей станции в EME Observer, смело отправляйте его мне.
Оригинал сообщения:
Thanks to the encouraging feedback from stations using EME Observer for 10 GHz QSO planning and moon footprint tracking, the tool now supports all bands from 432 MHz and above - choose band from the control panel.
A new Realtime Tracking mode has also been added - thanks to Jan PA0PLY for driving its introduction. Simply click the Track button to enable it. You can now also toggle Active/All stations to show only active ones and hide any past activations - a great suggestion from Zdenek OK1DFC, Guy F2CT, and Jan PA0PLY.
EME Observer’s station data is kindly provided by the excellent PA0PLY EME Directory, which Jan has maintained with great dedication for many years. Please check that your station information is up to date and send any updates to Jan PA0PLY.
If you would like to add an image of your station to EME Observer, feel free to send it to me.
73,
Max SA5IKN
« Ответ #370 : 01 Ноября 2025, 09:03:43 »
Свежий, октябрьский выпуск 432 и выше...
https://eme.radio/432-and-above-newsletter
« Ответ #371 : 23 Ноября 2025, 11:31:27 »
Спутники AST & Science LLC (AST SpaceMobile) представляют угрозу для наших операций EME на диапазоне 70 см
launch of the AST SpaceMobile satellite BlueBird 6...
...channels 430.5 MHz, 432.3 MHz, 434.1 MHz, 435.9 MHz, or 439.5 MHz with a maximum bandwidth of 50 kHz for uplink and downlink and only (!) outside the USA
« Ответ #372 : 25 Ноября 2025, 21:22:59 »
In memory of our friend Bernd DL7APV - DL7APV EME calendar 2026
« Ответ #373 : 27 Ноября 2025, 15:45:56 »
« Ответ #374 : 23 Декабря 2025, 13:35:12 »
Декабрьский № 432 AND ABOVE EME NEWS Volume 54 Number 12
WEB - 2025-12 Vol 54-12
PDF - 2025-12 Vol 54-12
