Автор Тема: Проект EVE25 (Земля - Венера - Земля)  (Прочитано 2593 раз)
« : 30 Январь 2025, 12:33:34 »
Довольно интересный эксперимент.
 Исходное сообщение Александра K6VHF в ЕМЕ рефлекторе (в оригинале и в "машинном" переводе).
Howdy.  EVE25(Earth-Venus-Earth) project is coming up soon (about 2 months to go) when Venus will approach close to Earth (38,000,000km). The system is assembled 95% and tested 80%. The feed was made in one day (thanks to KL6M for detailed instructions) and tested today. I've built three feeds in past and everything they work as designed.  I was impressed with feed performance from the first try. The RX port RL=43db!!, TX is about 35dB. I use SMA connector for RX and 7/16 for TX to hold 1.2kW.  Feed has choke and flare which actually improved the RX and TX RL and SWR.  Only isolation is low than I expected, measured 22dB, I'd like to see over 30dB of isolation.  I was playing with metal ring (50mm) inside the flare (per KB2SA presentation) and saw that isolation went up to 45db!!! what a change. I'll try to play more to find right position. The final tuning will take place when feed installed on dish.  Thanks to KL6M, OK1DFC, KB2SA, KA1GT for provided online material and support. Special thanks for OZ9AAR for excellent REPAM, over-current protection and RF head designs. All of them used on EVE25 system.  The detailed drawing of the system will be published after the project execution.  The EVE25 has unique design, fully remote with 32 points of telemetry and controlled via fiber-optic line. Every-single sub-unit has protection and remotely controlled. System capable operating on two bands 23cm and 13cm.
73 de K6VHF EVE25 Chief Design Engineer and Scientist
 Привет. Проект EVE25 (Земля-Венера-Земля) скоро начнется (примерно через 2 месяца), когда Венера приблизится к Земле (38 000 000 км). Система собрана на 95% и протестирована на 80%. Облучатель был изготовлен за один день (спасибо KL6M за подробные инструкции) и протестирован сегодня. Я уже построил три облучателя, и все они работают так, как задумано. Я был впечатлен производительностью облучателя с первой попытки. Порт RX RL=43 дБ!!, TX около 35 дБ. Я использую разъем SMA для RX и 7/16 для TX, чтобы удерживать 1,2 кВт. Облучатель имеет дроссель и расширение, что фактически улучшило RX и TX RL и SWR. Только изоляция ниже, чем я ожидал, измеренная 22 дБ, я бы хотел видеть более 30 дБ изоляции. Я экспериментировал с металлическим кольцом (50 мм) внутри раструба (согласно презентации KB2SA) и увидел, что изоляция выросла до 45 дБ!!! Какое изменение! Попробую поиграть еще, чтобы найти правильное положение. Окончательная настройка будет произведена, когда облучатель будет установлен на тарелку. Спасибо KL6M, OK1DFC, KB2SA, KA1GT за предоставленные онлайн-материалы и поддержку. Особая благодарность OZ9AAR за превосходный REPAM, защиту от перегрузки по току и конструкцию головки RF. Все они используются в системе EVE25. Подробный чертеж системы будет опубликован после завершения проекта. EVE25 имеет уникальную конструкцию, полностью удаленную с 32 точками телеметрии и управляемую через оптоволоконную линию. Каждый отдельный субблок имеет защиту и управляется дистанционно. Система может работать на двух диапазонах 23 см и 13 см.
73 de K6VHF Главный инженер-конструктор EVE25 и научный сотрудник
Очень надеюсь, что Александр K6VHF сам еще более подробно, по мере возможности, добавит информацию по этому проекту на форуме.
« Последнее редактирование: 30 Январь 2025, 12:37:25 от UD2F »
Re: Проект EVE25 (Земля - Венера - Земля)
« Ответ #1 : 30 Январь 2025, 15:20:42 »
Валентин, Vielen Dank ! ;-)
Но справедливости ради, дополню тему ссылкой на "исходную" информацию из Moon-Net - EVE25 is coming up soon с поступающими там комментами....   И началом обсуждения Проекта EVE25 у нас, с Ответ #881  "черезстрочно...."
« Последнее редактирование: 30 Январь 2025, 15:26:19 от Михалыч »
« Ответ #2 : 30 Январь 2025, 16:12:59 »
еплеровские элементы и скорости их изменения в системе средних эклиптики и экватора на эпоху J2000, пригодные на интервале времени с 1800 года по 2050 год.
Цифрами в колонках таблицы обозначены:
1      а.е, а.е. за столетие
2      радиан, радиан за столетие
3      градусы, градусы за столетие
4      градусы, градусы за столетие
5      градусы, градусы за столетие
6      градусы, градусы за столетие
_________________________________________________ ______________________________________
            1           2           3               4            5            6
Венера     0.72333566  0.00677672  3.39467605    181.97909950 131.60246718  76.67984255
           0.00000390 -0.00004107 -0.00078890  58517.81538729   0.00268329  -0.27769418
Попробовал кскопировать данные и вставить их в блокнот, чтобы получить .tle
- не получается, Орбитрон не принимает. С Марсом и другими планетами тоже не получается.
« Последнее редактирование: 30 Январь 2025, 16:16:04 от UA9FAD »
« Ответ #3 : 30 Январь 2025, 16:16:44 »
Зачем искать TLE для Венеры? Изначально это формат для объектов, которые вращаются вокруг Земли по баллистическим орбитам. То, что вращается вокруг Солнца считается не по TLE. Если взять бесплатную, мультиплатформенную программу Stellarium, то она показывает угол места и азимут для любого объекта во Вселенной для указанного QTH, только мышкой ткнуть. На больших расстояниях есть нюансы, конечно.
« Ответ #4 : 30 Январь 2025, 16:24:08 »
Игорь, идея в автосопровождении, расчете доплера и управлении трансивером. У меня Орбитрон связан с VK5DJ-beam controller и трансивером TS2000. Возможно есть другие варианты, пока начал с этого.
« Ответ #5 : 30 Январь 2025, 16:47:40 »
Виктор, так в том и дело, что TLE для Венеры нет. Считается она по Эфимеридам. Вроде Стеллариум умел телескоп на объект наводить, но не интересовался.
« Ответ #6 : 30 Январь 2025, 16:53:27 »
Игорь, да, я "умолчал" о Stellarium в предыдущих сообщениях, доча Даниэла, пару лет назад фанатично занялась астрофотографией (только периодически в ясную погоду принимаю команды "Пап поехали" _hi_hi) купили "бочку"-телескоп, монтировка сопряжена с Stellarium и до кучи RadioEyes, всё наводится точно. Как писал ранее в теме ЕME-1296 МГц, с "калькуляцией" VK3UM прошлых лет, для объектов дальнего космоса, на сегодня уже есть небольшие расхождения.
« Последнее редактирование: 30 Январь 2025, 17:13:49 от Михалыч »
Оффлайн ua1ccu
« Ответ #7 : 31 Январь 2025, 01:16:11 »
Здравствуйте. Антенна у него какая?
Константин.
« Ответ #9 : 31 Январь 2025, 17:45:55 »
K0PRT.
60-футовая антенна расположена в Хасуэлле, Колорадо, примерно в 90 милях к юго-востоку от Колорадо-Спрингс. Место называется Центром радиоастрономии и космических наук Пола Плишнера в честь нашего донора, который был одним из первых исследователей в области радаров. Эта антенна — одна из нескольких, построенных Национальным бюро стандартов (теперь NIST) для работы по тропосферному распространению в поддержку радара дальнего раннего оповещения (DEW) с 1957 по 1974 год. Эти антенны были расположены от Колорадо до Арканзаса.
Re: EVE25
От: Алекс K6VHF
Дата: Чт, 30 Янв 2025 13:51:31 UTC
Кстати, ребята из Бохумской обсерватории нам очень помогли и присоединились к проекту EVE25. В отличие от эксперимента CW в 2006 году (EVE2009), который был простым отражением CW "HI" с данными постобработки, эксперимент EVE25 предназначен для проведения ПЕРВОГО QSO EVE и ПЕРВОГО цифрового самодекодирования в реальном времени.
EVE2009 и EVE25 — это не одно и то же, за исключением факта отскока Венеры.
Бохумская обсерватория в Германии работала с командой DSES и проводила многочисленные встречи и обменивалась учебными материалами. У нас есть разные типы экспериментов, поэтому я НЕ понимаю, честно говоря, в чем цель этой темы. Все знают, что EVE25 — не первый эксперимент на Венере.
Все началось еще в начале 60-х, когда НАСА провело множество экспериментов с использованием радаров EVE, и так мы узнали, что либидо Венеры приближается к 70%.
« Последнее редактирование: 31 Январь 2025, 17:56:31 от UA9FAD »
Оффлайн ua1ccu
« Ответ #10 : 01 Февраль 2025, 10:09:15 »
Здравствуйте. А кто корреспонденты . Типа HB9Q с антенной  15 метров.   А что говорит  теория ...
Константин
Оффлайн RW6HM Yuri
  • QRA: LN14sg
« Ответ #11 : 01 Февраль 2025, 10:32:53 »
либидо Венеры
Прально,если-Венера,конечно либидо :D...Эт у остальных альбедо,им и этого хватит)))
« Ответ #12 : 01 Февраль 2025, 10:43:28 »
Все знают, что EVE25 — не первый эксперимент на Венере...
Я честно говоря, не помню, что бы в радиолюбительской литературе (на р.л. форумах, в том числе подобное описывалось).
Возможно что то и было, но прошло как то мимо радиолюбителей... Если не прав, поправьте...
Оффлайн RA3TES Андрей
  • QRA: LO15VJ
« Ответ #13 : 01 Февраль 2025, 11:18:16 »
Тут по считал немного... если до Венеры, во время, связи будет 38.000.000 км. то задержка в одну сторону будет примерно 2 минуты. Венера не улетит пока пока до нее сигнал идет ;-).
« Ответ #14 : 01 Февраль 2025, 11:24:49 »
 - German AMSAT Team Transmits, Receives Signals from Venus
 - Earth-Venus-Earth experiment of AMSAT-DL successful
