Автор Тема: Software for antenna rotators control  (Прочитано 3956 раз)
Оффлайн yo3dmu
« : 29 Январь 2011, 12:26:58 »
PstRotator is a program for antenna rotators control. You can try and download it from:
http://www.qsl.net/yo3dmu/index_Page346.htm
It works with a wide variety of rotators, supports a lot of loggers, DX cluster clients, satellites and moon trackers.
The program supports multi-user remote operation over the Internet.
The user interface offers quite a selection of methods for pointing and display, as well.
Оффлайн UT5JCW
  • Гости
  • QRA: KN64SN
Re: Software for antenna rotators control
« Ответ #1 : 29 Январь 2011, 13:08:24 »
A good job has been done by you. According to your ad you got a very competitive programm. I've downloaded it and will try it soon. Probably I would be along with it... Thanks for the posting here.
Оффлайн ua3pf Игорь
« Ответ #2 : 29 Январь 2011, 18:37:16 »
Greetings BUDA CODRUT!
I use UcxLog ver6.58
I operate AlfaSpid Rotor Azimut RAK.
Management Alfa Spid with use Windows XP.
The cursor in the course of communication constantly is in UcxLog (window CALL)
Vetom case your program can't operate the rotary device with use of the keyboard (arrow) keys.
How to make so, what the cursor would be active in window UcxLog, and management AlfaSpid Rotor Azimut RAK as would be active with keyboard use?
tnx!
E-mail: ua3pf@mail.ru
« Последнее редактирование: 29 Январь 2011, 18:42:18 от ua3pf Игорь »
Оффлайн yo3dmu
« Ответ #3 : 29 Январь 2011, 22:18:32 »
Hi Igor,
Please upgrade the PstRotator (to v6.73) or PstRotatorAz (to v4.93) program in order to work with the latest versions of the UcxLog (ver6.59).
In the PstRotator select UcxLog as Tracker and set Tracking to Mode.
Writing a callsign in UcxLog (window CALL) will pass it to PstRotator, wich will calculate the azimuth for this callsign (using cty.dat, call3.dat and VHF_USA.mdb files). Press "GO to DXCC" button to turn antenna on that direction.
Regarding your question, you can not have active the mouse in a window (UcxLog) and the keyboard in onother (PstRotator), in the same time. This is the Windows.... In order to use the arrows, you need to click on the PstRotator window.
73,
Codrut - YO3DMU
