Автор Тема: MSHV meteor scatter  (Прочитано 546378 раз)
Re: MSHV meteor scatter
« Ответ #510 : 25 Июня 2018, 10:54:51 »
-25.06.2018 - MSHV version 1.80
New in version 1.80:
    Added: In green cat control widget (mode, frequency and button F) option to write user defined frequency.
    How to: just single mouse click on cat control widget (widget becomes red); change frequency and then press button F or Enter.
    Corrected: In "Multi Answering Auto Seq Protocol" saving in log the correct RPT of QSO, detected by Zybi SP6CPH.
+ файл MSHV MS Locator database June 25, 2018 02:15 UTC (обновить заменой в ....\MSHV\settings\database\*.*)
« Последнее редактирование: 25 Июня 2018, 11:11:07 от Михалыч »
« Ответ #511 : 05 Июля 2018, 23:46:50 »
- 05.06.2018 - MSHV version 1.81
New in version 1.81:
    Added: In Options menu, "Font Settings" option, you can change fonts for application and list (fonts and font sizes), tested by Plamen LZ2PR and Gary K7EK.
    Changed: No-response time from 12 sec to 75 sec, for RIGs which do not support CAT reading during TXing.
    Corrected: Application freezing if you add new a QSO to a Log which contains more than 1,000 ones.
    Important: please do not work (TX/RX) with the program if Log widget is open. This will slow down the decoding progress.
+ MSHV MS Locator database July 05, 2018 02:15 UTC
« Ответ #512 : 17 Июля 2018, 14:22:01 »
- 17.07.2018 - MSHV version 1.82
New in version 1.82:
Added: In "Radio And Network Configuration", new Group box "UDP Broadcast Settings:" and two options for broadcast QSOs, Logged QSO Broadcast and Logged QSO ADIF Broadcast.
Important: Before update to new version, please backup your previous log from (dir log file mshvlog.edim).
Function "Logged QSO Broadcast" has an exception if you use Logger32: eg. In "Multi Answering Auto Seq Protocol", it is possible to end QSOs with 5 stations simultaneously within the same second. Logger32 will save only first QSO, for this reason, the seconds for each QSO, if they are in same minute, MSHV tags them electronically from 00-59.
UDP Broadcast has been tested with Logger32 for function "Logged QSO Broadcast" and N1MM for function "Logged QSO ADIF Broadcast".
Mailing lists - MSHV@groups.io
+ MSHV MS Locator database - July 17, 2018 02:15 UTC
« Ответ #513 : 01 Августа 2018, 16:35:37 »
- 01.08.2018 - MSHV version 1.83
New in version 1.83:
    Added: In mode CW option to monitoring one or two DX expeditions, for special message (OZ2M RR73; SP9HWY <LZ2HV> +00)
    if they work is in "Multi Answering Auto Seq Protocol" or DXpedition mode. For this option just need to type calls in to MONITOR R1 or R2 Labels.
 + MSHV MS Locator database August 01, 2018 02:15 UTC:
« Ответ #514 : 06 Августа 2018, 00:18:31 »
В процессе подготовки к Персеидам осваиваю софт. Не нашел как "быстрыми" клавишами очищать окно TO RADIO.
Кнопку RESET QSO видел, но удобней не мышью целиться, а нажать пару клавиш :) ) (старая DOS "закалка")...
« Ответ #515 : 06 Августа 2018, 16:24:17 »
Привет! Нажмите Ctrl+K увидите список и в нем  нет нет такой функции, увы.  Быстрее мышкой выделить и убрать кнопкой  Delete, но  это нежизненная  ситуация, а надуманная. Практически, внеся позывной в поле To Radio  и кликнув  Gen Msg, вы получите все поля заполненными, для формирования рапорта лучше пользоваться соответственными окошками.
« Последнее редактирование: 06 Августа 2018, 16:31:30 от UT9UR, Аркадий »
« Ответ #516 : 06 Августа 2018, 16:26:48 »
Спасибо Аркадий. Список "быстрых" сокращений смотрел до того, как писал свое сообщение - там нет.
Еще пока не всю эту тему про программу осилил :)), может где было ?
« Ответ #517 : 06 Августа 2018, 16:47:56 »
Валентин, а что ждать "Персеиды"? Можем прямо сейчас, или завтра утром, у меня есть скед с новой ДХСС (1700км).
Летает сейчас вяло, но что ж нам тут для такого расстояния высчитывать  best time!
Оффлайн RW3TJ
  • QRA: LO16XG
« Ответ #518 : 06 Августа 2018, 17:14:40 »
Ждем с......
Оффлайн US8AR
  • QRA: KO60RR
« Ответ #519 : 21 Августа 2018, 20:10:00 »
Добрый вечер! Есть ли инсталлятор программы для Linux в виде .deb пакета?
73! Nick US8AR
« Ответ #520 : 21 Августа 2018, 20:31:37 »
       Привет!  Это не оно?
"Download MSHV Debian Linux binaries 32 and 64-bit compiled by Peter - OZ1PIF". Только что отсюда без проблем:http://lz2hv.org
Оффлайн US8AR
  • QRA: KO60RR
« Ответ #521 : 21 Августа 2018, 20:38:13 »
       Привет!  Это не оно?
Без проблем на сайт. А на страницу загрузки? Какой то пароль надо вводить. К чему это?
http://prntscr.com/klbfxj
73! Nick US8AR
« Ответ #522 : 21 Августа 2018, 20:43:20 »
http://www.frenning.dk/OZ1PIF_HOMEPAGE/MSHV-Download.html
Прямой линк для deb пакетов. Только я тоже под линуксом не смог запустить перед Персеидами. У меня вообще не хочет ставить "галки" на виде модуляции и диапазоне. Кроме того не видит USB карту и переходник usb-com. Не стал пока тратить время на это.
Под виндой 7-й в потоке отработала программа хорошо, мне очень понравилось.
« Последнее редактирование: 21 Августа 2018, 21:23:21 от UD2F »
« Ответ #523 : 21 Августа 2018, 20:43:54 »
А....а да, пароль, я забыл, так-как он зашит в браузере. Пришлю на почту в архиве., возможно, двумя кусками. Надо >30мин (слабый доступ)/
        Вижу, появился пост Валентина. Вспомнил, что была небольшая переписка в рефлекторе по поводу проблем,  именно Линукс-версии, но не читал ибо не юзер. Николай, слать? Какую?
V1.83 64-bit Debian based
v1.83 32-bit Debian based
« Последнее редактирование: 21 Августа 2018, 20:51:39 от UT9UR, Аркадий »
Оффлайн US8AR
  • QRA: KO60RR
« Ответ #524 : 21 Августа 2018, 20:52:44 »
Прямой линк для deb пакетов. Только я тоже пол линуксом не смог запустить перед Персеидами. У меня вообще не хочет ставить "галки" на виде модуляции и диапазоне. Кроме того не видит USB карту и переходник usb-com. Не стал пока тратить время на это.
Я под Win10 тоже отработал. А сайт по ссылке - есть у меня. Только там не файл с расширением .deb, а зазипованная папка. Скачал, распаковал, из вложенной папки /bin запустил исполняемый файл - прога запустилась. Порт работает, звук нет. (((
Запускается только из папки. А из терминала через - sudo mshv - не запускается, потому как не устанавливалась.
Может отсюда и проблема со звуком? Хочу выяснить.
73! Nick US8AR
