Автор Тема: MSHV meteor scatter  (Прочитано 453249 раз)
Re: MSHV meteor scatter
« Ответ #2220 : 18 Август 2021, 21:35:19 »
Что я делаю не так? Или, всё-таки, программу нужно подправить?
Если установить второй экземпляр программы, в другую папку, и попробовать в работе, на эти вопросы, могут появится ответы.
Оффлайн LZ2HV
  • QRA: KN23SF
« Ответ #2221 : 19 Август 2021, 14:22:42 »
To UT9UR, Аркадий  (за рапорт изеяетса из ASeq)
To Михалыч, извиняйус предварителна, если можна перевод на ето, "tnx. in advance"
 for testing in MSK  RPT change from ASeq   https://drive.google.com/drive/folders/1cxtPc9xqRpxfzqq1LFF8C6MmQjcHQS_s
MSHV_WIN64_259_007.zip
Logic is:
Report is locked after you in TX2,TX3 and ->ON<-  TXing,  if still in RX report is no locked yet
Report is unlocked on TX1,TX6,TX7, mode changed, band changed
IN:
TX1 Report is unlocked,  Report is unlocked if click to waterfall, Report is unlocked if double click on Decode list
TX2 Report is locked when TXing to the end of QSO,  Report is locked if click to waterfall to the end of QSO, Report is unlocked if double click on Decode list
TX3 Report is locked when TXing to the end of QSO,  Report is locked if click to waterfall to the end of QSO, Report is unlocked if double click on Decode list
TX4 Report is locked when TXing to the end of QSO,  Report is locked if click to waterfall to the end of QSO, Report is unlocked if double click on Decode list
TX5 Report is locked when TXing to the end of QSO,  Report is locked if click to waterfall to the end of QSO, Report is unlocked if double click on Decode list
TX6 Report is unlocked ,  Report is unlocked if click to waterfall, Report is unlocked if double click on Decode list
TX7 Report is unlocked ,  Report is unlocked if click to waterfall, Report is unlocked if double click on Decode list
Pse. test and results (in console you will see lock unlock moments)
LZ2HV Christo.
Онлайн RA3VGV
  • 9el RA3AQ 500ватт
« Ответ #2222 : 21 Август 2021, 09:05:39 »
Коллеги. версия 2.43 как активировать сплит? В окне qrg пишу 350. макрос тх7 меняется на 350. Передача идет на 360 прием тоже 360. Окошко qrg не краснеет.
http://SSMaker.ru/8084f3ac/
сат естественно работает. При перестройки частоты на трансивере в программе тоже меняется.
Оффлайн Alex R6AS
  • QRA: kn85tc
« Ответ #2223 : 21 Август 2021, 18:40:53 »
Костя  привет ... а нажать  на кнопку не пробовал ......
Онлайн RA3VGV
  • 9el RA3AQ 500ватт
« Ответ #2224 : 21 Август 2021, 19:00:39 »
на какую? не нажимается говорю ж)
Оффлайн RC3UE
  • 13 el F9FT/21 el F9FT
  • QRA: LO07NG
« Ответ #2225 : 21 Август 2021, 19:41:35 »
Константин, не выноси мозг товарищам! ;)
Поставь MSHV 2.58, и все дела. Проверяли же с тобой - все там работает.
Даже при приеме вызова на сплит-частоте, программа сама переходит на передачу на ней.
В 2.43, скорее всего, этот функционал не был еще реализован.
Оффлайн Alex R6AS
  • QRA: kn85tc
« Ответ #2226 : 22 Август 2021, 08:39:47 »
......Sorry ......не помню.....по старинке пользовался   SPLIT  в TRX ...
« Ответ #2227 : 08 Сентябрь 2021, 17:34:20 »
 - 08.09.2021 - MSHV version 2.59
New in version 2.59:
    Added: In Menu Options, Other Options, check box "Use Queue (For Contest Activitiеs Only)".
    Added: Possibility to change TX report on the fly for FT4 mode, from Automatic Sequencing (ASeq) or if you double click on Decode List.
    Added: Possibility to change TX report on the fly for FT8 mode if you double click on Decode List.
    Changed: Latency for UDP broadcast Decoded Text Messages from 1000 ms to 40 ms.
    Changed: In mode MSK, if you use Automatic Sequencing (ASeq), after your first TX with report, "report" will be locked to the end of QSO.
    Added: Possibility to use TCI clients only as CAT control, and for TX/RX sound cards or VAC cables.
Новое в версии 2.59:
Добавлено: В «Параметры меню», «Другие параметры» установите флажок «Использовать очередь (только для соревнований)».
Добавлено: возможность изменять отчет TX на лету для режима FT4, с автоматической последовательности (ASeq) или если вы дважды щелкните список декодирования.
Добавлено: возможность изменять отчет TX на лету для режима FT8, если дважды щелкнуть по списку декодирования.  Изменено: Задержка для широковещательных UDP-декодированных текстовых сообщений от 1000 мс до 40 мс.
     Изменено: В режиме MSK, если вы используете автоматическую последовательность (ASeq), после вашей первой передачи с отчетом "отчет" будет заблокирован до конца QSO.
Добавлено: возможность использовать клиентов TCI только в качестве управления CAT, а также для звуковых карт TX / RX или кабелей VAC.
  LZ2HV Amateur Radio Website
The machines rose from the ashes of the nuclear fire.......
« Ответ #2228 : 08 Сентябрь 2021, 22:17:56 »
      Сергей, RX1AS и другие, которые писали о том, что нужно сохранять первоначально переданный рапорт в моде МСК144
                                      (в том числе я, ),
как видим, в этой версии предложение удовлетворено!  Перевод машинный и решил написать.
"Изменено: В режиме MSK, если вы используете автоматическую последовательность (ASeq), после вашей первой передачи с отчетом "отчет" будет заблокирован до конца QSO. "
   Следует понимать слово "отчет", как более привычное для тусовки слово "рапорт".   Для моды ФТ8 так же можно изменять на лету рапорт, если кликнуть по декодированному списку. Отлично! Больше порядка, а то потом непонятно, что в ЛОГ записывать и у корреспондента более объективное представление о приеме его сигнала. И вообще-это по ПРАВИЛАМ МС, рапорт не меняется, как начал передавать -2, так потом хоть +20 будет, но передавать надо -2. Во время HSMSCW рапорта не меняли и это все знали, кроме того было принято сообщать на VHF-NET, 14,345 и писать на ЩСЛ карточке кроме рапорта еще и кол-во бурстов, пингов и наибольшую длительность. У меня есть карточки от истинных джентльменов с расписанным протоколом периодов, сколько в каждом чего было принято.
« Последнее редактирование: 08 Сентябрь 2021, 22:26:34 от UT9UR, Аркадий »
Оффлайн RZ3RZ
  • QRA: LO02RR
« Ответ #2229 : 13 Сентябрь 2021, 23:06:09 »
Подскажите в моде JT65B как можно  раздельно изменить звуковые частоты
TX - RX  (это можно сделать в моде FT-8 и в проге WSJT-X)
Нужно для компенсации Доплера в ручную при отсутствии CAT
Может Христо подскажет или сделает для всех мод одинаковую возможность их раздельного изменения. (кнопка LTR)
« Последнее редактирование: 13 Сентябрь 2021, 23:09:03 от RZ3RZ »
Сергей, Тамбов
Оффлайн RX1AS Сергей
« Ответ #2230 : 14 Сентябрь 2021, 07:15:23 »
Лучше всего с Доплером на 144 МГц ничего не предпринимать и не думать о нём.
« Ответ #2231 : 14 Сентябрь 2021, 08:35:30 »
Скорее всего Сергей имеет ввиду 70 см. Но путь он выбрал какой-то не стандартный :( (
В теме по ЕМЕ 70 см вам дали практический совет, если у вас не работает компенсация в программе WSJT-X. Есть вообще целая тема по доплеру, там есть что почитать... Но так, как вы сейчас хотите сделать, я еще не слышал...
« Ответ #2232 : 14 Сентябрь 2021, 09:14:17 »
  ......это называется "чесать левое ухо правой ногой".
1. Сдвигом частоты от эффекта Доплера на 144 заниматься стоит. Только в одном случае, когда пайл-ап и нужно отъехать в сторону. Для этого нужно понимать суть. Я пользуюсь постоянно, более чем в 50% ЕМЕ ЩСО. Суть-это имеется ввиду понимание обстоятельств: где ДХ, на каком континенте находится, стандартная ли у него частота звука (1270-1300Гц), какой Доплер у вас и у ДХ, кто его зовет и какой у них Доплер.И наконец, куда вам надо отъехать, чтобы ДХ вас видел там (где у него чисто), а не тут, где толпа. Это долго ситать, но поверьте, дело привычки и решение получается менее, чем за пол-минуты.
2. Делается сдвиг элементарно-расстройкой ТХ, которая есть во всех трансиверах. СПЛИТ не нужен и частоту звука менять не нужно.
3. Сергей, RX1AS пишет: "Лучше всего с Доплером на 144 МГц ничего не предпринимать и не думать о нём."
         Это политика "тяжеловеса", могущего себе позволить не обращать внимание на граждан в троллейбусе и идущего на выход по чужим ногам. Кто понял-посторонится. Именно схожая ситуация описана Питером в соседней теме-время "окна"  на Европу малое, а он видел зовущих, но никого не смог декодировать, ибо все в куче. Так что лучше отойти на.....Гц. Обычно я ухожу на 200-300Гц и таким макаром работал даже на старом РА с ГС31. Куда-это вопрос другой, но повторюсь, дело привычки.
                    ИТОГО: частоту звука менять не надо. Для JT65B она должна быть 1270Гц, но это не строго, на практике у людей 1200-1500Гц без видимого ущерба. Но если у меня скед со слабым корреспондентом и я его не вижу, то иногда спрашиваю его аудио частоту и тогда, зная сдвиг Доплера я ищу его в нужном месте на водопаде, отсекая бывающие "несучки".
« Последнее редактирование: 14 Сентябрь 2021, 09:16:27 от UT9UR, Аркадий »
Оффлайн RZ3RZ
  • QRA: LO02RR
« Ответ #2233 : 14 Сентябрь 2021, 12:22:47 »
Спасибо за ответы.
Общую суть конечно понимаю.
Но в цифре в руках мышка и в чем разница двинуть частоту расстройкой или звуковой тх в проге. Доплер как правило не превышает 500 гц. Может конечно фильтры прог настроены только на указанные частоты звука?
Сергей, Тамбов
« Ответ #2234 : 14 Сентябрь 2021, 21:55:16 »
Принципиальной разницы нет, можно отъехать на 200Гц, но при таком варианте нельзя выходить за пределы  звукового тракта, обычно 300-2800, может 300-3400Гц, но зачем, когда есть функция XIT-увод частоты передатчика! Кроме того, малое значение зв.частоты может породить вторую гармонику, которая свободно пройдет через фильтр.
                      Более добавить нечего. Если вы понимаете суть происходящих процессов, то можно поиграть вопреки советам, на то и дело наше-любительское. Успехов!
