Автор Тема: софт для УКВ тестов  (Прочитано 82236 раз)
Re: софт для УКВ тестов
« Ответ #210 : 30 Июнь 2015, 09:59:04 »
5MContest НАПРИМЕР, всё поддерживает...
Кроме сети.
Это почему же, есть в 5М сеть и даже номера почти не прос... пропускает и не дублирует, в отличии от всяких н1мм-ов.
Программа хорошая, но не для старых компов и не для освоения экстерном за 5 дней до контеста.
« Последнее редактирование: 30 Июнь 2015, 10:17:15 от Sergi »
« Ответ #211 : 06 Февраль 2016, 22:38:37 »
Есть надежда наконец-то получить нормальный контест софт под unix системы:
Hi everyone.
Here are couple of information I would like to share with all of you at
DXLog.net mailing list.
Some of these are already published on FB page, but let me share little bit
more information now.
For more than a month I am working on completely new code for DXLog, which
will move us from .net and C#
code and move it into new and faster code, with multi platform
possibilities.
So, DXLog v3 will be moved to C++ code. For GUI elements, we are using QT
Widgets now, which will allow
us to build DXLog for different operating systems. Currently build is
tested for Windows and Linux OS, and next
step is to test this code in OS X..
In this moment, about 50% of forms are already rewritten with new code and
I hope that in about a month beta testers
will be able to start testing beta versions on their own hardware. During
next days, development of the code for hardware communication will be
started, so there will be a lot of testing in front of us during this month
too.
Of course,without .net framework, c++ code runs much faster and there are
much less problems with different threads interaction etc.
In meantime, DXLog.net development is continued, I expect new release to be
published during next week.
Functionalities supported in .net version will be supported in v3 version,
but there will be some new features implemented in early versions as well.
Any ideas and suggestions are really appreciated.
73,
Chris - 9A5K
Оффлайн UA7C
  • RT6A Team
« Ответ #212 : 08 Март 2016, 16:17:43 »
... Ну вроде не пять дней до ПД...
Установил 5м. Пока два вопроса.
1. А где вводить свой собственный локатор, чтобы очки считала и азимут показывала? В "Установки/Станция" координаты она сама поставила, когда позывной ввёл - 45N39O.
2. Если используется трансвертер, куда ввести частоту опоры, в моём случае 130 МГц, чтобы правильно САТ работал?
Николай
Оффлайн RA9DA
  • RA9DA Николай
  • QRA: mo17mp
« Ответ #213 : 08 Март 2016, 18:20:01 »
1 В "Установки/Станция" Контр.номер
2 Настройки Omni-rig VHF transverter
Оффлайн UA7C
  • RT6A Team
« Ответ #214 : 08 Март 2016, 18:41:08 »
RA9DA TNX!
Нет под рукой трансивера, попробую позже, но вроде понял.
Ввёл свой локатор. Пробую заносить связи. В окошке "УКВ азимут, дистанция" пишет только расстояние, азимута нет. Да и расстояние неправильно считает.
Что не так делаю? Номер и квадрат корреспондента надо слитно вносить?
И ещё вопрос, занёс несколько QSO на 144МГц, закрыл программу, запустил снова, выбрал "продолжить контест", а он начинает давать нумерацию опять с 001. Что неправильно делаю?
Николай
Оффлайн RA9DA
  • RA9DA Николай
  • QRA: mo17mp
« Ответ #215 : 08 Март 2016, 18:57:12 »
да,причем нули впереди можно не вводить
А какая версия?
В последней, у меня примерно также
при переключении в другой тур, номера с 001 начинались
исправлял вручную, и дальше опять нормально
Оффлайн UA7C
  • RT6A Team
« Ответ #216 : 08 Март 2016, 19:08:42 »
А какая версия?
Последняя. С сайта скачал.
Может я глупый вопрос задаю... А там нет возможности, чтобы номер в своём окошке, а квадрат в своём, ну, как в других программах?
P.S. не понял про туры, я вроде бы ПД выбрал, он же без туров...
Николай
« Ответ #217 : 08 Март 2016, 19:40:01 »
Все верно.
Для организации работы с турами надо выбрать вместо ПД - Минитест и описать необходимые установки по турам ( время, номера).
А зачем номер в своем окошке, а квадрат в своем?
Вы прописываете свой квадрат в установках и он подставляется автоматически.
Я вот пока не понял, как выбрать русский язык в макросах SSB, пока не получается, чтобы автоматически проговаривал номер и квадрат по русски.
Фразы наговорить и заменить по русски - это без проблем.
Удачи!
Программа очень хорошая!
Спасибо Виталию!
« Ответ #218 : 08 Март 2016, 19:48:39 »
5MContest отличная прграмма, есть рефлектор на googlegroups.com. Если начать задавать-отвечать-обсуждать вопросы, как сделать-включить-отключить функции, то это будет явно  вне задач этого форума. Я не модерирую,просто предупреждаю, что тема большая,  так сказать:"Электрон также неисчерпаен,как и атом!".  Сам проект с участием автора, "живой" и развивающийся. Если хотите с этой программой работать-подпишитесь. Имеет "хэлп" и видеоролики по отдельным вопросам.
   Конкретно по вопросу Николая. Такой возможности нет. Для раздельной нумерации по диапазонам нужно включить сеть, если включена-при запуске будет табличка с напоминанием об этом.
    Программа классная, современная, имеет свои "ноу-хау".
Если наговорили файлы с текстами,то включается это в настройках макросов. Сейчас не дома,конкретно не скажу. Другое дело, что пользы от автоматики в тлф. у меня не получилось, все работает, но смысла нет и народ путается услышав необычную, "машинную" дикцию. ИМХО и я оставил тлф. до лучших времен.
П.С. Азимут расстояние в отдельном окошечке,надо включить его. программа выдает безукоризненный отчет, в том числе .EDI, принимается всеми серверами. автор сторого придерживается ПРОТОКОЛОВ.
Удачи!
« Последнее редактирование: 08 Март 2016, 20:04:50 от UT9UR, Аркадий »
« Ответ #219 : 08 Март 2016, 20:05:35 »
Доброго дня, Аркадий!
Цифры по русски есть в штатном варианте в папке Sound (Х_рус.wav), насчет пользы пока не знаю, но на КВ применяют, поэтому хотел попробовать.
Заранее благодарю за подсказку. В "хэлпе" не нашел.
« Ответ #220 : 08 Март 2016, 20:14:48 »
Здравствуйте. Сергей!
На КВ  тлф. не пробовал. Но для освоения этой программы работал года два в КВ тестах тлг. и цифровыми видами. Заготовить файлы не просто, те которые от автора,сделаны классно и под них подстроить не просто. потратил много времени на доводку в разных больших программах обработки звука, теперь новый позывной и надо бы заново все делать, но душа не лежит к тлф. Хотя в УКВ соревнованиях в начале, тлф. проводяться десяток-другой ЩСО.
« Ответ #221 : 08 Март 2016, 20:23:26 »
Я уже более 5 лет с этой программой на КВ, однако в основном SSB.
Но не в российских тестах, поэтому раньше  и не задавался этой задачкой.
А на УКВ, в Сибири, противоположная картина по соотношению CW/SSB QSO, наверно, как 10/90. Теряем лучшие по дальности QSO.
Но в этом сезоне попробуем изменить этот порочный подход, будем посмотреть, что получится.
В CW к программе нареканий нет, можно приспособить под себя.
Оффлайн RA9DA
  • RA9DA Николай
  • QRA: mo17mp
« Ответ #222 : 09 Март 2016, 06:51:13 »
6 числа у нас был Кубок Попова на УКВ
Скачал последнюю версию перед этим
и работал,и работаю на этой программе с начала моего УКВ (2013)
когда переключил на второй тур, нумерация переключилась на 001
вручную исправил на нужный номер и дальше нормально было, до 3 тура
3 тур, опять пришлось исправлять
в старых версиях такого не было
Нужно записать файлы своим голосом и заменить в макросах
Еще лет 10 назад, слышал от одного уважаемого контестмена
- сутки проработал в SSB тесте и никто не заметил, что это компьютер говорил
все зависит от записи и настройки
зачем надрываться и кричать, когда это может сделать программа
« Ответ #223 : 09 Март 2016, 07:06:27 »
Добрый день, Николай!
Вы не совсем правильно поняли.
Еще раз. Цифры на русском наговаривать нет необходимости.
Они есть в проге, по крайней мере у меня в последней версии.
А вот как прописать в макросе замену англ. на рус?
В эфире RC9O, Анатолий давно использует компьютер, а не орет голосом.
Я сам использовал в CQ WW в ночное время, чтобы не тревожить домашних, но там все на англ. и номер не меняется (5918 и привет).
Оффлайн RA9DA
  • RA9DA Николай
  • QRA: mo17mp
« Ответ #224 : 09 Март 2016, 07:46:31 »
Я не хочу вещать не своим голосом
поэтому записал все файлы своим голосом, чужие удалил из папки
файлы имеют вид (Х_rus)
МАКРОС  ~[NUM]
ГОВОРЮ на русском
