Автор Тема: Частотный план и зона покрытия QO-100  (Прочитано 24849 раз)
Re: Частотный план и зона покрытия QO-100
« Ответ #15 : 22 Сентябрь 2019, 14:54:31 »
по видимому, пиратские отголоски...
Peter Gülzow | DB2OS | AMSAT-DL - сообщет:
To all QO-100 users and friends,
We urgently need your help and support!
This morning (around 05:25-05:33 UTC, 2019-09-22) Alarms were triggered in the Es'hailSat satellite control center in Qatar due to High Power uplink on the NB transponder!
Considering the safety of transponder they may SWITCH OFF the QO-100 transponder in case if it exceeds the limits again.
Please accept and respect the transponder guidelines rules and band plans.
    Please stop running high power, even not for experiments or try-out! If you want to test your power, please use a dummy load and power meter.
    Keep your Downlink strength at the same level as the CW Beacon, maximum one S-Unit above will be tolerated!
    Stay within the borders of the transponder. Do not transmit below the CW Beacon and do not transmit above the PSK Beacon!
Please help everyone on QO-100 to adjust operation practices accordingly.
Please be friendly and polite with other OMs on QO-100, but don't hesitate to give them reports.
Please spread the words!
Original notification below:
    Quote
    "Am 22.09.2019 um 08:30 schrieb CMCdesk:
    Dear Peter,
    Please note that we observed high transmission power of AMSAT NB carrier around 05:25 - 05:33 UTC today 22.09.2019, our satellite control team also observed high input power and triggered alarms on their system, considering the safety of transponder they may MUTE ON the transponder in case if it exceeds the limit again.
Could you please check with customer to not exceeds the nominal power."
Для всех пользователей и друзей QO-100,
Нам срочно нужна ваша помощь и поддержка!
Этим утром (около 05: 25-05: 33 UTC, 2019-09-22) в центре управления спутником Es'hailSat в Катаре сработала сигнализация из-за высокой мощности восходящей линии связи на транспондере NB!
Учитывая безопасность транспондера, они могут ОТКЛЮЧИТЬ ретранслятор QO-100 в случае, если он снова превысит пределы.
Пожалуйста, примите и соблюдайте правила и рекомендации группы транспондеров.
Пожалуйста, прекратите работать на большой мощности, даже не для экспериментов или проб! Если вы хотите проверить свою мощность, пожалуйста, используйте    фиктивную нагрузку и измеритель мощности.
Сохраняйте силу нисходящей линии на том же уровне, что и CW Beacon, максимально допустимый S-блок выше!
Оставайтесь в границах транспондера. Не передавайте ниже CW Beacon и не передавайте выше PSK Beacon!
Пожалуйста, помогите всем на QO-100 соответственно скорректировать методы работы.
Пожалуйста, будьте дружелюбны и вежливы с другими ОМ на QO-100, но не стесняйтесь сообщать им.
Пожалуйста, распространите это сообщение!
Оффлайн R3ICQ Илья
  • QRA: KO77LJ
« Ответ #16 : 22 Сентябрь 2019, 15:24:15 »
Этим не объяснишь) Успей сработать пока не запароли транспондер Ну ведь такая ситуация рано или поздно появилась бы. А вот,что делать с этим? Ничего. Просто выключат. Кловунов  хватает
« Последнее редактирование: 22 Сентябрь 2019, 15:51:40 от R3ICQ Илья »
« Ответ #17 : 22 Сентябрь 2019, 19:27:36 »
В эти выходные проходит ARRL EME contest 2.3 GHz and up, 13cm - 2304/2320 MHz, но мог кто нибудь "дунуть" EU - Japan EME, японское (IIRC) EME окно 2424.000 - 2424.500 MHz, и попал в спутник ;-) в 5:30 UTC Луна рядом была.
.....вот Leila-цвай и слетела с катушек ;-)))
Оффлайн F4EQE
  • QRA: jn38uo
« Ответ #18 : 22 Сентябрь 2019, 20:54:03 »
Сейчас рядом с телеметрией хрюкают в ФМ . Видно что мощность большая.
« Ответ #19 : 23 Сентябрь 2019, 23:48:04 »
появилась новая группа в groups.io - GEO (Geostationary Earth Orbit) amateur radio satellite for the Americas
и, пока несколько Messages, возможно, когда то появится "собрат" QO-100 над западным полушарием...
Оффлайн F4EQE
  • QRA: jn38uo
« Ответ #20 : 24 Сентябрь 2019, 00:15:18 »
Инфо по запуску Р4В на сегодняшний день пока так - 2020 January - AFSPC-12: WFOV (Wide Field of View Testbed missile-warning satellite), ESPA - Atlas V - Canaveral SLC-41
И еще здесь https://space.skyrocket.de/doc_sdat/wfov.htm
« Последнее редактирование: 24 Сентябрь 2019, 00:27:10 от F4EQE »
Оффлайн r5au
  • Сергей, R5AU (ex RA3AJK)
  • QRA: KO85TB
« Ответ #21 : 24 Сентябрь 2019, 09:16:32 »
Всё таки информации по частотам так и нет  cqkosmos
73! , Сергей
Оффлайн F4EQE
  • QRA: jn38uo
« Ответ #22 : 24 Сентябрь 2019, 12:36:21 »
 P4B AMSAT-NA project two GSO with transponders 10 GHz down and 5.6 GHz up.
« Последнее редактирование: 24 Сентябрь 2019, 13:04:42 от F4EQE »
« Ответ #23 : 06 Октябрь 2019, 19:21:45 »
Обновлённая презентация - The latest QO-100 Presentation (okt. 2019)
« Ответ #24 : 07 Октябрь 2019, 20:08:59 »
Октябрь - месяц осенней солнечной интерференции, Солнце будет находится на одной оси с QO-100, точное время (в районе обеда) желающие понаблюдать это явление (или измерить шум Солнца не двигая антенну) рассчитайте самостоятельно, даты пика 11 - 14 числа, по калькулятору VK3UM при NF LNA = 0.8dB фоновое зашумление будет составлять для парабол 1m - 7.6dB, для 0.8m - 6.1dB, для 0.6m - немногим менее 5dB...  и т.д.
Если будет время, сделаю "замеры" и картинки.
Sun Outage / Sun Interference Prediction for Geostationary Orbit Satellites
« Ответ #25 : 14 Октябрь 2019, 13:15:46 »
"зашумлён" водопад - Солнце за спутником!
Оффлайн UA3TCF
  • QRA: LO26iu
« Ответ #26 : 15 Октябрь 2019, 14:51:43 »
Только сегодня измерил шум Солнца, когда оно было вблизи спутника QO-100. Немного опоздал по дате, Солнце сегодня проходило уже 0.8 гр ниже. Тем не менее, шум Солнца был 5.5 дБ по SpectraVue. Антенна 125 см оффсет, LNB SRT L739.
73! Александр
« Ответ #27 : 24 Октябрь 2019, 08:37:19 »
Давно пользуюсь Триколором и несколько раз менял голову по причине продырявливания радиопрозрачной крышки и заполнения её водой. Видимо в такие дни весной и осенью крышке "достается" порция ультрафиолета ;) - если безоблачная ясная погода.
« Ответ #28 : 24 Октябрь 2019, 09:13:19 »
Достаётся ! ;-)
В конце 80-ых, была самодельная стекловолоконная тарелка 120cm, оклеенная алюм. фольгой, не было тогда интернета подсказать, так вот март и октябрь, дважды за год, была проплавлена насквозь, крыша облучателя ;-)))
Картинка с шумом, на 10 октября, Солнце выше спутника на 3 градуса, самый максимум "пекла", был числа 14-го
« Ответ #29 : 03 Ноябрь 2019, 02:31:25 »
Читал, да так ни чего и не понял ;-)) что общего между DL0SHF и QO - 100 ...
о проекте NASA Artemis Lunar Gateway - Lunar Gateway - Лунные врата ;-)
 и здесь - Satellite : La Balise EME 10 GHz DL0SHF (10368.024) et AO-100 ....что такое Le Sat AO-100 ?
