Доброго время дня всем! Как обстоят дела с отправкой отчетов!???
Что за ерунда, не принимается отчет не на основной адрес fd@vhfdx.ru робот футболит
This message is automatically created by HA1AH Contest Evaluator Software ( ha1ah.freeweb.hu ).
Please don't reply it directly to the sender's address.
Original sender: ua9uiz@kemtel.ru
Original subject: Отчет UA9UIZ за соревнование ПД 2010
ERROR_EDI_IDENTIFIER_NOT_FOUND: EDI file identifier [REG1TEST;1] is not found at the beginning of the file.
If you intended to send us this file as described in the contest rules file please correct the errors and send it again.
If you didn't send the appropriate file format but another format and you can send the required format then do it, please.
Otherwise ignore this mail.
Please note that YOUR LOG IS NOT ACCEPTED BY THE CONTEST COMMITTEE SINCE IT CONTAINS SEVERE ERRORS!!!
You can find the file you sent in the attachment.
If you have any questions or remarks please use our information e-mail address: field.day@yandex.ru
Note that you can also submit your log on the home page of the contest: http://www.vhfdx.ru/field_day
You also can check your logs and the list of stations already submitted logs and can get other useful information on the contest home page.
_________________________________________________
Ad:
SecDrive makes your Internet access safe, secure and anonymous.
www.secdrive.com
twitter.com/secdrive
With SecDrive you can reach blocked web pages & Internet services.
SecDrive provides virtual disk with file sharing feature for you.
www.secdrive.com
Easy file backup & restore with SecDrive.
и не дополнительный field.day@yandex.ru тоже
Это письмо отправлено почтовым сервером yandex.ru
К сожалению, мы вынуждены сообщить Вам о том, что Ваше письмо не может
быть отправлено одному или нескольким адресатам. Причины указаны ниже.
Пожалуйста, не отвечайте на это сообщение.
This is the mail system at host yandex.ru
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
Please, do not reply to this message.
<field.day@yandex.ru>: host 127.0.0.1[127.0.0.1] said: 550 5.2.2 No such user
yet!; gQL0cRmN (in reply to end of DATA command)
Отчет составлен как обычно прогой UA4NAL прошлые годы небыло проблем...отсылались "OTCHET" и пробовал "OUT" и отдельно файлы EDI...
