Автор Тема: Контроллер VK5DJ  (Прочитано 17160 раз)
Оффлайн RX9AT Владимир
  • QRA: LO93LJ
Re: Контроллер VK5DJ
« Ответ #120 : 16 Ноябрь 2024, 18:22:16 »
И ещё, может что то поможет.
Цитата
Version 9.51 for a 4 line 40 character LCD (this is the same as version 10.00 except it supports a 4 line display)
I've written the 9.51 version for a 4 line display. Two LCDs have been trialled
(1) HDM40416L from Futurlec.
(2) LKC-4004 from lcdmodkit.com
I've used the extra two lines and the wider display to permanently display the UTC time and local time (offset is set in the menu), moon declination and display the doppler shift and the frequency when the moon is above the horizon. Because this LCD actually has two controllers on board I have had to use the unused DTR pin on the computer interface J1 (pin 4) to enable the second controller for the bottom 2 lines. If you are interested send me an email.
Цитата
Wiring a 4 line display with Version 9.51
The four line displays used in this version of the project are really two displays in one. There
are two enable pins and the system works by enabling the top two lines, writing the
information, then disabling the top display and enabling the bottom two lines then writing the
information there. It all works quite well.
You will need to check the data sheet for the display you buy. It must be HD44780
compatible. Locate the two enable pins. The first enable pin goes to the usual pin 6 on P1 of
the main board. The second enable pin goes to pin 4 of J1. In the original version this pin 4
was the DTR connection to the computer, this is no longer used for that purpose and has been
programmed in the four line LCD version to be a second enable pin.
73! de RX9AT Владимир
  • QRA: LO93LJ
« Ответ #121 : 16 Ноябрь 2024, 18:40:50 »
При сборке и настройке своего контроллера использовал эти данные.
Оффлайн R9YA Павел
  • QRA: NO22qn
« Ответ #122 : 17 Ноябрь 2024, 15:57:30 »
Да Владимир, почитал перевод и обнаружил у себя, что с дисплея не подключены два контакта 5 и 6. Шестой из перевода как раз и нужен для включения второй половины дисплея. У меня на печатке нет вообще этих контактов, а в схеме есть.
Интересно у кого как дисплей подключен к контроллеру, есть ли не подключенные контакты? Может они и не нужны и тогда нужно дальше искать.
73! Pavel R9YA (ex RX9JP)
Оффлайн RW4WP Виктор
  • QRA: LO66CX
« Ответ #123 : 17 Ноябрь 2024, 16:08:01 »
Павел,у Вас на схеме 2х строчный дисплей.Схем с 4х строчным я не видел.Его надо соединять согласно печатной платы .Нумерация один к одому
Все на УКВ
Оффлайн R9YA Павел
  • QRA: NO22qn
« Ответ #124 : 17 Ноябрь 2024, 16:30:31 »
У меня в реальности 4-х строчный дисплей WH4004A, который подключен как в схеме. У 4-х строчника 18 выводов в отличии от 2-х строчника, у него 16. И если разницы в  подключении нет, то почему на схеме 5 и 6 выводы подключены а на печатке нет. Да и у 2-х строчника совсем другая нумерация выводов.
В общем в этом разнобое схем и печаток я уже не понимаю, где и что кому соответствует.
Кстати у меня вот такая печатка и она схеме местами не соответствует:
« Последнее редактирование: 17 Ноябрь 2024, 16:36:10 от R9YA Павел »
  • QRA: LO66CX
« Ответ #125 : 17 Ноябрь 2024, 16:36:48 »
У 4х строчного дисплея не подключены к плате  5,6, 7,8 выводы.На печатнойплате их нет.
Все на УКВ
  • QRA: LO93LJ
« Ответ #126 : 18 Ноябрь 2024, 09:54:30 »
Доброго дня!
Павел, ваша печатка верна, только почему-то с вывода 10 пика стоит 300 ом идущие на 15ый вывод дисплея.
Его там не должно быть или поставить примерно ом-50 и то наверное много. Выводы дисплея 9 и 15 равноценны.
Они как раз разрешают работу двух половинок дисплея.
« Ответ #127 : 18 Ноябрь 2024, 10:21:11 »
У меня плата от UA9YLU, индикатор WH4004A, подключен как на фото.
  • QRA: LO93LJ
« Ответ #128 : 18 Ноябрь 2024, 10:26:27 »
И ещё, если есть осцил., поглядите на выводах 10 и 35 пика должны быть импульсы и такие-же импульсы должны бать на 9 и  15 выводе дисплея.
Оффлайн R9YA Павел
  • QRA: NO22qn
« Ответ #129 : 20 Ноябрь 2024, 18:12:18 »
Александр, у меня такая же плата от YLU и дисплей такой же, но вот не хочет работать. На фрагменте у Вас 16 вывод дисплея в воздухе, а у меня распаян, но отпайка его тоже ничего не дает.
Если можно сбросьте полную распечатку этой платы, а не фрагмент.
Владимир, проверил осликом на всех перечисленных контактах, везде есть частота, правда с небольшим уровнем. На 13 и 14 контактах пика тоже кварц генерит с приличным уровнем.
Еще раз перепрошивал разные прошивки, 12.7.2, 12.9 и 9.51, все для 4-х строчного дисплея, но всегда только две строки, с разницей только версии.
Пробовал еще перемкнуть сопротивление 300ом идущее от 10ножки пика к 15 дисплея, никакой разницы. Где косяк не пойму.
« Ответ #130 : 20 Ноябрь 2024, 20:52:36 »
 У моего разъем с боку и ряды разъема там четные и не четные. Может всё же что-то перепутали? Завтра гляну какая у меня прошивка залита. Посмотрел раньше вы фото выкладывали. Проверить шлейф на прозвон ,может где обрыв.
« Последнее редактирование: 20 Ноябрь 2024, 20:55:09 от RX3DR Александр »
  • QRA: LO66CX
« Ответ #131 : 20 Ноябрь 2024, 20:56:35 »
Павел,что-то меня берут сомнения в исправности индикатора.Я делаю два контролера-одна плата от UA9FA,другая от YLU.Обе платы запустились.Завтра буду подключать энкодеры.
Все на УКВ
Оффлайн rw9og
  • QRA: NO14ns
« Ответ #132 : 21 Ноябрь 2024, 05:35:44 »
Такая беда:  Не считываются показания энкодеров, при включении на платах  AZ и EL светятся оба светодиода, на дисплее в верхней строке отображается   AZ 360.00 EL 0.00  и не меняются. Основная плата и платы AZ и EL от UA9YLU
Оффлайн Roman_hs19
  • Sine metu
« Ответ #133 : 21 Ноябрь 2024, 06:22:54 »
А энкодеры какие?
С уважением, Роман R6FJ
LN24cr
Оффлайн rw9og
  • QRA: NO14ns
« Ответ #134 : 21 Ноябрь 2024, 07:13:42 »
энкодеры на магнитах
