Автор Тема: Fox Hunting Activity on QO-100 Satellite  (Прочитано 545 раз)
Оффлайн R3KEE
    • My HAM
  • QRA: KO91oh
« : 15 Мая 2021, 09:29:52 »
Dear Friends;
During these pandemic days we anted to have another activity for children who are at home and away from their friends. Also wanted to support the eTwinning Learning Project our community volunteer and education coordinator/teacher Aysegul Dundar, Mars On Earth Project Team. Not only to support their education and have an awareness about hamradio and/or space communications also to play an old hamradio game altogether on a satellite transponder.
Foxhunting (also known as radio direction finding) is a field game under normal circumstances, where there are hidden and randomly transmitting tiny transmitters in a big field which I trying to be found by the attendee gamers. When you find a transmitter location (called fox) you get points which means you hunt a fox. We don’t harm any animal during this activity.
This time, because of pandemic situation, we will not have a chance to be outdoors. Like our previous QO-100 KGSTV activity we wanted to hunt the foxes on our geostationary satellite transponder QO-100. This time we will be at home, monitoring the QO-100 downlink frequencies. Here is the story and procedure to be part of this activity:
Random SSB voice transmissions will be conducted on QO-100 SSB transponder portion,
Transmission times will be randomized withing the given activity hours,
Transmission frequencies will be random within a few frequency range,
You will try to capture and record the transmissions as good and long as possible (hunt the fox),This transmission will include a chiled’s voice recording with his/her message to space and a secret letter for this challenge,
Sending these recordings and the secret word (refer to rules) to us will reward you with an award for the activity.
Activity Date & Time
15 May 2021 15:00 UTC to 17:00 UTC
16 May 2021 15:00 UTC to 17:00 UTC
Other Detail Info (English)
https://marsonearthproject.org/fox-hunting-on-qo-100-satellite/
Regards
перевод в 2х словах.:
на частотах:
10489670 – 10489680 kHz
10489700 – 10489710 kHz
10489770 – 10489780 kHz
10489810 – 10489820 kHz
Будет осуществлять передачу в течение 1 (одной) минуты на любой из точечных частот в произвольном расписании/времени,
Передача будет включать в себя следующую информацию (голос),
- Передача начнется с чередующихся тонов в течение 3 секунд (чтобы быть легко замеченным),
- Передача радиосигнала идентификации (OH2UDS или OH2CAV),
- Сообщение от ребенка в КОСМОС, который является частью “Образовательного проекта eTwinning”,
- Сообщение закончится подсказкой для секретное слово : “а секретное письмо ... .”,
- Конец передачи с передачей чередующихся тонов,
Для участия необходимо:
- записать сообщение как можно дольше,
- нужно захватить секретные письма. Сочетания секретных писем даст секретное слово.
(на странице по ссылке в письме есть таблица для заполнения)
Подсчет очков происходит следующим образом;
Вам нужно записать передачу на электронное устройство (e.г. телефон, компьютер) и отправьте записанный файл команде MarsOnEarthProject
Формат записи должен быть одним из следующих;
wav
mp3/mp4
au/aac
огг
3gpp
Вам необходимо записать (записать) дату, время и частоту передачи в лог-файл (напр.г.: текстовый файл на компьютере),
Каждый файл сообщения может быть передан только один раз,
Одна и та же запись может быть отправлена только одним участником,
Время записи в секундах будет вашей базовой точкой (e.г. 50 секунд записанной передачи это 50 баллов),
Запись и сообщение секретного письма для передачи добавляет “10” дополнительных очков,
Вы можете использовать столько станций/устройств, сколько захотите (например,г. несколько веб-страниц SDR, несколько спутниковых антенн),
Использование автономного приема (dish и sdr/ legacy radio) добавляет 10 дополнительных очков для этого приема,
Секретное слово-это дополнительные 500 очков для участника.
Отправка Журналов И Записей
Вам необходимо отправить следующую информацию команде проекта ” Марс на Земле "по электронной почте" marsonearthproject@gmail.com “;
Ваше имя и возраст,
Детали вашей станции (например, объясните, что вы использовали для работы в этой деятельности, в свободном текстовом формате, URL веб-SDR, детали оборудования),
Текстовый файл, содержащий все даты приема, время и частоты. Этот файл журнала может содержать секретную букву для получения дополнительных очков,
Пожалуйста, обратите внимание на длину захваченной передачи в лог-файл для каждого приема,
Пожалуйста, обратите внимание на имя файла записи для каждой записи журнала в вашем файле журнала,
Загрузите все ваши записи на веб-диск или общую среду онлайн и отправьте нам ссылку на файлы записи,
Вся информация должна быть отправлена в одном электронном письме,
Примерная строка журнала может быть следующей;
Позывной (опционально) : TA7W
Возраст : 47 лет
Расположение : Трабзон – Турция
Станция : WebSDR on http://websdr.is0grb.it:8901/
73! Roman.
