Автор Тема: 5 GHz to 10 GHz Lunar Transponder Mission  (Прочитано 1350 раз)
Оффлайн UA3ATQ
« : 07 Сентября 2016, 22:03:25 »
https://amsat-uk.org/2016/09/07/5-ghz-to-10-ghz-lunar-transponder-mission/
AMSAT-NA plan a satellite carrying transponders for 5 GHz to 10 GHz that is expected to launch into a Lunar orbit in September 2018.
Heimdallr is a 3 axis stabilized 6U CubeSat with a mass of approximately 8 kg. It will have a Cold Gas Thruster for inertia dump and a star tracker for navigation. Deployable, gimbled solar panels will produce up to 100 watts of DC power, electric propulsion will be used to achieve lunar orbit.
There will be a combination of omni and directional patch antennas on one side of spacecraft.
The first part of mission is to provide Telemetry, Tracking, and Command (TT&C) to obtain lunar orbit. The second part is to perform the data downlink experiment while the final part is to provide a two way regenerative repeater and analog repeater in lunar orbit for lifetime of satellite.
Proposing these downlinks:
• Omni transponder: 10.451 GHz +/- 0.5 MHz
• Directional transponder: 10.4575 GHz. +/- 3.5 MHz
• Analog transponder: 10.4665 GHz. +/- 2.0 MHz
For the first part of the mission (TT&C) using 300 bps BPSK 1/2 rate viterbi Ranging 1.5 Mbps BPSK DSSS. For the  second part of mission 4.5 Mbps QPSK ½ rate DVB-S2. For the final part of mission 25 kbps BPSK 1/5 rate DVB-S2.
Proposing these Uplinks
• Omni transponder: 5.651 GHz +/- 0.5 MHz
• Directional transponder: 5.6575 GHz. +/- 3.5 MHz
• Analog transponder: 5.665 GHz. +/- 2 MHz
A link budget is available at
https://drive.google.com/folderview?id=0B3u-mSOWBMISYnZyZGJpeThKeU0&usp=sharing
It is anticipated that a 1 or 2 metre dish will be required using the AMSAT designed ground station equipment.
Source IARU Satellite Frequency Coordination Status pages http://www.amsat.org.uk/iaru/
Re: 5 GHz to 10 GHz Lunar Transponder Mission
« Ответ #1 : 07 Сентября 2016, 22:28:15 »
Серьезный аппарат.
