Автор Тема: FO-29  (Прочитано 122185 раз)
Оффлайн RX9AT Владимир
  • QRA: LO93LJ
FO-29
« : 02 Мая 2007, 17:28:06 »
Может кто то в курсе,почему замолчал FO-29?
Post edited by: RX9AT, at: 2007/05/02 18:35
73! de RX9AT Владимир
Отв:FO-29
« Ответ #1 : 02 Мая 2007, 22:58:17 »
На amsat.org сообщили, что спутник по всей видимости умер.
Отв:FO-29
« Ответ #2 : 03 Мая 2007, 07:31:35 »
http://www.southgatearc.org/news/april2007/fo29_help_wanted.htm
JARL ищет телеметрию, которая была после 20-го апреля ибо замолчал он 21.
Отв:FO-29
« Ответ #3 : 18 Августа 2007, 17:56:44 »
Сегодня утром было слышно маяк и ретранслятор работал. Там проблемы с батареей и устройством управления питанием. В общем есть по японски подробнее на http://www.jarl.or.jp/Japanese/3_Fuji/new/information.htm
 По английски не нашел, но на cqham F0EQE сообщил следующее: The internal impedance of the battery in FO-29 (Fuji-3) is now rising due to the deterioration caused by almost 12 years in orbit. According to the telemetry data a 25 minute eclipse duration is estimated as a limit as for the analog battery system use. Because the eclipse length of FO-29 (Fuji-3) is currently about 30% or almost 32 minutes, the power supply of the relay with the battery cannot serve a period of the eclipse.
A malfunction also occurs in part of the electricity control system. The malfunction is the UVC which is an automatic function for electricity management. When the satellite is in the eclipse, and the light of the sun is not the solar battery, the transmitter is turned OFF by the UVC. It is designed so that later an analog system transmitter becomes ON automatically when the terminal voltages of the battery exceed a set value after the power is available from the solar battery. However, it appears likely that a malfunction occurs for this function, and the terminal voltage cannot turn on a transmitter even if it exceeds the set value unless commanded from the ground.
The length of eclipses for FO-29 (Fuji-3) will rise in future and rises to 34% in March 2008 and comes over a peak of the eclipse duration. When it goes over this peak, the eclipses will decrease slowly, and drop to 20% in August 2009. By February 2010 it is all sunshine with no eclipses for about 8 months. It seems that we can apply the analog system relay consecutively for this period.
Post edited by: RW3XL, at: 2007/08/18 18:58
Отв:FO-29
« Ответ #4 : 09 Сентября 2007, 08:58:45 »
Получил письмо от JA0BBW. Он пишет:
"FO-29 was come back and  testing Now.
Please Uplink Ok. to FO-29
Pse QSP to EU station's."
Расписание работы можно посмотреть на
там правда по японски все, но циферки арабские :)
Оффлайн ES3RF-Геннадий
    • ES3RF: Estonian hamradio station
  • QRA: KO29IF
Отв:FO-29
« Ответ #5 : 09 Сентября 2007, 09:49:31 »
Да, у FO-29 проблемы с бортовым питанием.
Очевидно, каким то образом его, все таки, частично реанимировали. SV1BSX (Makis) сообщил следующее расписание работы спутника (применительно к Европе).
FO-29 sched 5-20 Sep
DATE || QRV1 UTC | QRV2 UTC
Sep 5 || 03:35 | 05:21
Sep 8 || 04:20 | 06:10
Sep 9 || 03:27 | 05:12
Sep11 || 03:25 | 05:07
Sep12 || 04:12 | 06:00
Sep13 || 03:20 | 05:03
Sep14 || 04:07 |
Sep15 || 03:15 | 04:58
Sep16 || 04:05 | 05:50
Sep17 || 03:10 | 04:55
Sep19 || 03:05 | 04:50
Sep20 || 03:55 | 05:40
К сожалению, сам проверить не смог, поскольку полная реконструкция антенного хозяйства и работать в эфире не могу.
Геннадий
ES1RF/ES3RF
Геннадий, ES3RF
Since 1961, ex: UA2ACS, UA2CS, UR2RGM, ES1RF
Оффлайн UA4UAA Валерий
Re: FO-29
« Ответ #6 : 29 Августа 2009, 23:34:13 »
 Так работает ли сейчас FO-29?
Оффлайн RW0LDF
  • QRA: PN74vj
Re: FO-29
« Ответ #7 : 30 Августа 2009, 01:47:58 »
Я давно его не слышал. Позавчера и вчера точно нет.
Re: FO-29
« Ответ #8 : 30 Августа 2009, 09:41:28 »
Сегодня весь виток слышал маяк 435.350+-.
Оффлайн RK4SWF
Re: FO-29
« Ответ #9 : 02 Сентября 2009, 22:20:14 »
я спутник тоже не слышу! :(
Оффлайн R9TA
  • QRA: LO63TP
Re: FO-29
« Ответ #10 : 03 Февраля 2010, 18:37:30 »
Спутник FO-29 работает, но всю орбиту провел в гордом одиночестве. С лышно здорово, во всяком случае себя. Пробуйте следующую орбиту, хотя может быть и не каждую орбиту он включается.
73! Андрей Абдулино LO63TP
Re: FO-29
« Ответ #11 : 03 Февраля 2010, 20:31:07 »
FO-29 работает.HO-68 тоже FM.
Оффлайн R9TA
  • QRA: LO63TP
Re: FO-29
« Ответ #12 : 03 Февраля 2010, 20:41:52 »
HO-68 понятно, что работает до 7.02 в FM, но как?
А в FO-29 сейчас работал. Работает прекрасно, как раньше. Пожил бы подольше.
Re: FO-29
« Ответ #13 : 04 Февраля 2010, 01:09:12 »
Хорошо работал сегодня ФО-29, активности станций не было, всю орбиту звал на CQ телеграфом, но только на самом "закате" удалось провести QSO c поляком.
Оффлайн NickName
  • Оставил форум в начале 2018
  • QRA: EARTH
Re: FO-29
« Ответ #14 : 25 Августа 2010, 15:44:08 »
Сегодня было 3 QSO на FO-29 за один проход (~ 11:50 utc): JA0BBW, JH0PVF, JA0CAW.
Локаторами не обменивались, но судя по поиску на vhfdx.net, все из PM97, максимальный QRB - 7248 км.
