Автор Тема: SumbandilaSat на орбите  (Прочитано 17348 раз)
Оффлайн W6BVB
« : 18 Сентябрь 2009, 18:35:08 »
SB SPACE @ ARL $ARLS007
ARLS007 South African Amateur Radio Payload Reaches Orbit
ZCZC AS07
QST de W1AW
Space Bulletin 007  ARLS007
From ARRL Headquarters
Newington, CT  September 18, 2009
To all radio amateurs
SB SPACE ARL ARLS007
After several delays, South Africa's SumbandilaSat satellite finally blasted to orbit aboard a Soyuz rocket from the Baikonur Cosmodrome in Kazakhstan on September 16. The main payload is a multi-spectral imager, but the satellite also carries an Amateur Radio component consisting of a 2 meter/70 cm FM repeater.
After SumbandilaSat is fully commissioned, the repeater will be activated with an uplink at 145.880 MHz and a downlink at 435.350 MHz; there will also be a voice beacon at 435.300 MHz. The transponder mode will be controlled by a CTCSS tone on the uplink frequency. The CTCSS tone frequencies have yet to be announced.
SumbandilaSat was sponsored by the Department of Science and Technology and was built at SunSpace in cooperation with the Stellenbosch University.
In addition to the SA-AMSAT amateur module, the satellite carries Stellenbosch University's radiation experiment and software defined radio (SDR) project, an experiment from Nelson Mandela Metropolitan University and a VLF radio module from the University of KwaZulu-Natal.
NNNN
/EX
Краткий перевод:
Союз доставил на орбиту новый радиолюбительский спутник SumbandilaSat.  Спутник будет работать в режиме FM-репитора 144/430
Uplink:145.880 Downlink:435.350. CTCSS код пока неизвестен.
Компиляция компиляторов дело рук самих компиляторов.
пенсионер
Re: SumbandilaSat на орбите
« Ответ #1 : 18 Сентябрь 2009, 19:49:01 »
А кто знает когда будет активирован или инфу
Оффлайн W6BVB
« Ответ #2 : 19 Сентябрь 2009, 04:55:50 »
http://en.wikipedia.org/wiki/SumbandilaSat
« Ответ #3 : 19 Сентябрь 2009, 12:12:41 »
А кепсы у кого-нибудь есть для этого спутника? Так же интересно было бы узнать нелюбительские частоты, на предмет сравнения силы сигнала там и там.
Оффлайн ra4ctr
« Ответ #4 : 19 Сентябрь 2009, 12:45:57 »
SUMBA2
1 35870U 09049F   09260.92529515 -.00000070  00000-0  00000+0 0    11
2 35870  97.3743 311.0021 0009230 287.0950  72.9081 15.22943597    38
Оффлайн RK4SWF
« Ответ #5 : 20 Сентябрь 2009, 06:12:00 »
похоже пока отключен спутник! я его не слышу!
пенсионер
« Ответ #6 : 20 Сентябрь 2009, 10:00:56 »
Орбита в 11-24 мск начнется с севера на юг, у меня прямо над головой будет если эти данные не устарели
Оффлайн UA9UIZ
  • QRA: NO46ge
« Ответ #7 : 20 Сентябрь 2009, 10:20:20 »
Пока маяк выключен...
73 de UA9UIZ Анатолий
« Ответ #8 : 20 Сентябрь 2009, 14:24:08 »
А у кого-нибудь эти кепсы нормально работают в SatPC32?
Оффлайн ra4ctr
« Ответ #9 : 20 Сентябрь 2009, 16:23:29 »
Свежие кепсы всех объектов, выведенных за данный запуск - кто из них кто не совсем ясно пока
на amsat.org вроде значится как объект 35867, впрочем с предыдущими данными разница не велика
METEOR-M
1 35865U 09049A   09261.85130047  .00000176  00000-0  10000-3 0    40
2 35865 098.8004 312.0250 0003601 080.8898 279.2547 14.21823900   165
OBJECT B
1 35866U 09049B   09261.85092753 +.00000178 +00000-0 +10000-3 0 00055
2 35866 098.8017 312.0296 0004292 075.2211 284.9295 14.22293025000167
OBJECT C
1 35867U 09049C   09262.83922800  .00002262  00000-0  10000-3 0    90
2 35867 097.3749 312.8740 0008567 282.8306 122.0522 15.22695743   323
OBJECT D
1 35868U 09049D   09261.85109579  .00000177  00000-0  10000-3 0    39
2 35868 098.8018 312.0258 0005228 064.2470 295.9091 14.22081443   168
OBJECT E
1 35869U 09049E   09261.85117771 +.00000176 +00000-0 +10000-3 0 00043
2 35869 098.8005 312.0239 0005611 075.6109 284.5570 14.21975938000161
FREGAT/IRIS
1 35870U 09049F   09262.43664686  .00002269  00000-0  10000-3 0    58
2 35870 097.3737 312.4736 0010296 291.3006 068.6949 15.22786707   261
NIMIQ 5
1 35873U 09050A   09261.60000000 -.00000087  00000-0  00000+0 0    35
2 35873 012.9660 295.1090 4548841 359.6390 088.0300 01.75731127    22
« Последнее редактирование: 20 Сентябрь 2009, 16:35:35 от ra4ctr »
Оффлайн ra4ctr
« Ответ #10 : 20 Сентябрь 2009, 16:54:09 »
Работают, совпадает с Орбитроном 1 в 1
« Ответ #11 : 20 Сентябрь 2009, 17:01:55 »
Спасибо, буду искать ошибку. Пока SatPC32 ругается при активировании спутника
"ungultige gleitkommaoperation". Орбитрон все показывает нормально.
Оффлайн ra4ctr
« Ответ #12 : 20 Сентябрь 2009, 17:06:09 »
Посмотрите какие служебные символы (типа LF CR ) идут по окончании строк и сравните с другими кеплерами, вроде как SATPC32 к этому капризный
Оффлайн R3UD
  • QRA: LO06MX
« Ответ #13 : 21 Сентябрь 2009, 05:35:09 »
Всем привет! Обидно когда запускаются эти болванки имею в ввиду чм ретрансляторы. А как хочется хорошего высокоорбитного типа FO-29, жалко что он умер, даже японцы и то не смогли обеспечить  питания от солнечных батарей. Одна радость VO-52.
Владимир.
R3UD - Владимир
Оффлайн RA4SAT
  • [url=http://nick-name.ru/nickname/id1192456/][img]
  • QRA: LO45ev
« Ответ #14 : 09 Октябрь 2009, 12:49:56 »
Приветствую! работает репитер на SumbandilaSat ??? я слушал вчера пока ничего нет! :-\
UA4SN Team
