# X[mm] Длина эл. [mm]
R1 0.0 339.4
A 50.0 299.0 <--- Петлевой вибратор. Расстояние между половинками 50мм по осям.
D1 117.2 310.4
D2 181.1 297.9
D3 322.4 304.2
D4 530.7 298.2
D5 779.0 292.5
D6 1048.4 288.2
D7 1330.2 284.8
D8 1620.8 281.8
D9 1919.0 279.1
D10 2223.6 276.5
D11 2533.3 274.1
D12 2846.6 272.0
D13 3162.0 270.2
D14 3478.1 268.7
D15 3793.5 267.6
D16 4107.0 266.9
D17 4416.2 266.7
D18 4720.0 268.6
D19 4980.0 270.6
GW 1 31 0.000 -169.722 0.000 0.000 169.722 0.000 2.250
GW 2 31 -25.000 -149.521 50.000 -25.000 149.521 50.000 2.250
GW201 31 25.000 -149.521 50.000 25.000 149.521 50.000 2.250
GW202 3 -25.000 -149.521 50.000 25.000 -149.521 50.000 2.250
GW203 3 -25.000 149.521 50.000 25.000 149.521 50.000 2.250
GW 3 31 0.000 -155.207 117.176 0.000 155.207 117.176 2.250
GW 4 31 0.000 -148.939 181.053 0.000 148.939 181.053 2.250
GW 21 31 0.000 -152.095 322.375 0.000 152.095 322.375 2.250
GW 5 31 0.000 -149.103 530.683 0.000 149.103 530.683 2.250
GW 6 31 0.000 -146.267 779.016 0.000 146.267 779.016 2.250
GW 7 31 0.000 -144.110 1048.360 0.000 144.110 1048.360 2.250
GW 8 31 0.000 -142.397 1330.160 0.000 142.397 1330.160 2.250
GW 9 31 0.000 -140.905 1620.770 0.000 140.905 1620.770 2.250
GW 10 31 0.000 -139.525 1918.980 0.000 139.525 1918.980 2.250
GW 11 31 0.000 -138.230 2223.556 0.000 138.230 2223.556 2.250
GW 12 31 0.000 -137.034 2533.285 0.000 137.034 2533.285 2.250
GW 13 31 0.000 -135.977 2846.625 0.000 135.977 2846.625 2.250
GW 14 31 0.000 -135.076 3162.022 0.000 135.076 3162.022 2.250
GW 15 31 0.000 -134.345 3478.062 0.000 134.345 3478.062 2.250
GW 16 31 0.000 -133.788 3793.543 0.000 133.788 3793.543 2.250
GW 17 31 0.000 -133.442 4106.980 0.000 133.442 4106.980 2.250
GW 18 31 0.000 -133.356 4416.196 0.000 133.356 4416.196 2.250
GW 19 31 0.000 -134.290 4720.049 0.000 134.290 4720.049 2.250
GW 20 31 0.000 -135.294 4980.000 0.000 135.294 4980.000 2.250
CE RA3AQ AQ70-23F 50 Ohm
GW 1 31 0.000 -169.200 0.000 0.000 169.200 0.000 2.250
GW 2 31 -25.000 -149.162 50.000 -25.000 149.162 50.000 2.250
GW201 31 25.000 -149.162 50.000 25.000 149.162 50.000 2.250
GW202 3 -25.000 -149.162 50.000 25.000 -149.162 50.000 2.250
GW203 3 -25.000 149.162 50.000 25.000 149.162 50.000 2.250
GW 3 31 0.000 -156.882 137.000 0.000 156.882 137.000 2.250
GW 4 31 0.000 -152.663 304.000 0.000 152.663 304.000 2.250
GW 5 31 0.000 -149.223 522.000 0.000 149.223 522.000 2.250
GW 6 31 0.000 -146.423 777.000 0.000 146.423 777.000 2.250
GW 7 31 0.000 -144.400 1047.000 0.000 144.400 1047.000 2.250
GW 8 31 0.000 -142.617 1331.000 0.000 142.617 1331.000 2.250
GW 9 31 0.000 -141.050 1626.000 0.000 141.050 1626.000 2.250
GW 10 31 0.000 -139.717 1929.000 0.000 139.717 1929.000 2.250
GW 11 31 0.000 -138.596 2237.000 0.000 138.596 2237.000 2.250
GW 12 31 0.000 -137.630 2549.000 0.000 137.630 2549.000 2.250
GW 13 31 0.000 -136.838 2864.000 0.000 136.838 2864.000 2.250
GW 14 31 0.000 -136.159 3180.000 0.000 136.159 3180.000 2.250
GW 15 31 0.000 -135.544 3498.000 0.000 135.544 3498.000 2.250
GW 16 31 0.000 -134.977 3816.000 0.000 134.977 3816.000 2.250
GW 17 31 0.000 -134.445 4136.000 0.000 134.445 4136.000 2.250
GW 18 31 0.000 -134.026 4455.000 0.000 134.026 4455.000 2.250
GW 19 31 0.000 -133.652 4774.000 0.000 133.652 4774.000 2.250
GW 20 31 0.000 -133.496 5092.000 0.000 133.496 5092.000 2.250
GW 21 31 0.000 -133.725 5406.000 0.000 133.725 5406.000 2.250
GW 22 31 0.000 -134.824 5712.000 0.000 134.824 5712.000 2.250
GW 23 31 0.000 -137.089 5980.000 0.000 137.089 5980.000 2.250
GS 0 0 0.001
Дмитрий, а не могли-бы Вы посчитать 23 эл элементы 4,5 мм с лежачим вибратором? Технически такой вибратор гораздо удобнее.
У меня гнутый прямоугольный диаметр 5,5 мм
GW 1 25 0.000 -170.949 0.000 0.000 170.949 0.000 2.250
GW 2 25 0.000 -150.489 40.000 0.000 150.489 40.000 2.750
GW201 25 0.000 -150.489 90.000 0.000 150.489 90.000 2.750
GW202 3 0.000 -150.489 40.000 0.000 -150.489 90.000 2.750
GW203 3 0.000 150.489 40.000 0.000 150.489 90.000 2.750
GW 3 23 0.000 -157.900 142.209 0.000 157.900 142.209 2.250
GW 4 23 0.000 -152.771 300.685 0.000 152.771 300.685 2.250
GW 5 23 0.000 -149.142 514.437 0.000 149.142 514.437 2.250
GW 6 23 0.000 -146.402 766.420 0.000 146.402 766.420 2.250
GW 7 23 0.000 -144.131 1039.244 0.000 144.131 1039.244 2.250
GW 8 23 0.000 -142.231 1325.777 0.000 142.231 1325.777 2.250
GW 9 23 0.000 -140.674 1622.187 0.000 140.674 1622.187 2.250
GW 10 21 0.000 -139.449 1925.716 0.000 139.449 1925.716 2.250
GW 11 21 0.000 -138.446 2234.026 0.000 138.446 2234.026 2.250
GW 12 21 0.000 -137.613 2545.569 0.000 137.613 2545.569 2.250
GW 13 21 0.000 -136.882 2859.381 0.000 136.882 2859.381 2.250
GW 14 21 0.000 -136.193 3174.936 0.000 136.193 3174.936 2.250
GW 15 21 0.000 -135.503 3492.083 0.000 135.503 3492.083 2.250
GW 16 21 0.000 -134.821 3810.794 0.000 134.821 3810.794 2.250
GW 17 21 0.000 -134.183 4130.702 0.000 134.183 4130.702 2.250
GW 18 19 0.000 -133.669 4451.168 0.000 133.669 4451.168 2.250
GW 19 19 0.000 -133.306 4771.314 0.000 133.306 4771.314 2.250
GW 20 19 0.000 -133.223 5089.649 0.000 133.223 5089.649 2.250
GW 21 19 0.000 -133.564 5403.123 0.000 133.564 5403.123 2.250
GW 22 19 0.000 -134.362 5705.075 0.000 134.362 5705.075 2.250
GW 23 19 0.000 -137.120 5980.000 0.000 137.120 5980.000 2.250
GS 0 0 0.001
F= 426.00 G= 17.736( 18.459)dB E= 98.355% G/T= 3.363dB Z=( 48.104 -2.680)
F= 428.00 G= 18.169( 18.756)dB E= 98.151% G/T= 3.949dB Z=( 51.242 0.677)
F= 430.00 G= 18.660( 19.007)dB E= 97.825% G/T= 4.305dB Z=( 52.678 0.761)
F= 432.00 G= 19.141( 19.205)dB E= 97.323% G/T= 4.415dB Z=( 50.009 1.362)
F= 434.00 G= 19.532( 19.343)dB E= 96.627% G/T= 4.292dB Z=( 49.036 4.024)
F= 436.00 G= 20.172( 19.377)dB E= 95.192% G/T= 3.669dB Z=( 47.013 -0.501)
F= 438.00 G= 20.367( 19.258)dB E= 92.584% G/T= 2.492dB Z=( 49.999 1.652)
а тут - параметры совпали идеально, включая Z, SWR, Jx.Почти идеально, в модели на 441 МГц КСВ 25, а у вас меньше 1,5
CE RA3AQ AQ70-24F 50 Ohm
GW 1 25 0.000 -172.602 0.000 0.000 172.602 0.000 2.250
GW 2 21 0.000 -151.420 35.000 0.000 151.420 35.000 2.250
GW201 21 0.000 -151.420 75.000 0.000 151.420 75.000 2.250
GW202 3 0.000 -151.420 35.000 0.000 -151.420 75.000 2.250
GW203 3 0.000 151.420 35.000 0.000 151.420 75.000 2.250
GW 3 23 0.000 -158.626 132.982 0.000 158.626 132.982 2.250
GW 4 23 0.000 -153.284 273.182 0.000 153.284 273.182 2.250
GW 5 21 0.000 -149.264 457.430 0.000 149.264 457.430 2.250
GW 6 21 0.000 -146.554 647.213 0.000 146.554 647.213 2.250
GW 7 21 0.000 -145.530 858.966 0.000 145.530 858.966 2.250
GW 8 21 0.000 -144.175 1106.542 0.000 144.175 1106.542 2.250
GW 9 21 0.000 -142.643 1378.054 0.000 142.643 1378.054 2.250
GW 10 21 0.000 -141.176 1664.393 0.000 141.176 1664.393 2.250
GW 11 21 0.000 -139.851 1960.831 0.000 139.851 1960.831 2.250
GW 12 21 0.000 -138.697 2264.402 0.000 138.697 2264.402 2.250
GW 13 19 0.000 -137.747 2572.786 0.000 137.747 2572.786 2.250
GW 14 19 0.000 -136.912 2884.527 0.000 136.912 2884.527 2.250
GW 15 19 0.000 -136.206 3198.787 0.000 136.206 3198.787 2.250
GW 16 19 0.000 -135.614 3514.391 0.000 135.614 3514.391 2.250
GW 17 19 0.000 -135.099 3831.043 0.000 135.099 3831.043 2.250
GW 18 19 0.000 -134.667 4148.166 0.000 134.667 4148.166 2.250
GW 19 19 0.000 -134.332 4465.306 0.000 134.332 4465.306 2.250
GW 20 19 0.000 -134.121 4781.522 0.000 134.121 4781.522 2.250
GW 21 19 0.000 -134.124 5096.031 0.000 134.124 5096.031 2.250
GW 22 19 0.000 -134.468 5406.078 0.000 134.468 5406.078 2.250
GW 23 19 0.000 -136.231 5710.598 0.000 136.231 5710.598 2.250
GW 24 19 0.000 -137.709 5960.000 0.000 137.709 5960.000 2.250
GS 0 0 0.001
F= 427.00 G= 18.846( 18.808)dB E= 98.065% G/T= 4.401dB Z=( 47.529 -4.276)
F= 429.00 G= 19.052( 19.020)dB E= 97.896% G/T= 4.633dB Z=( 51.500 -1.008)
F= 431.00 G= 19.219( 19.191)dB E= 97.654% G/T= 4.700dB Z=( 53.387 -0.071)
F= 433.00 G= 19.339( 19.313)dB E= 97.310% G/T= 4.609dB Z=( 53.124 1.019)
F= 435.00 G= 19.397( 19.373)dB E= 96.814% G/T= 4.333dB Z=( 52.185 0.895)
F= 437.00 G= 19.373( 19.351)dB E= 96.045% G/T= 3.813dB Z=( 46.734 0.858)
F= 439.00 G= 19.223( 19.202)dB E= 94.361% G/T= 2.819dB Z=( 48.672 -2.046)
Можно ожидать, что модель, имеющая два параметра, широкополосность и устойчивость,
проявит себя лучше в неблагоприятных условиях. Параметры взаимосвязаны, но всё же
две одинаково широкополосные модели могут повести себя по разному.
Действительно, при малейшем изменении сегментации характеристики сильно изменяются.
Наверное ошибки бывают и положительные.НА кабеле около вибратора- феррит?
Нет - стаканчик. Пробовал феррит без стакана - добавляет 0,2 к КСВ и влияние на расположение кабеля.Александр. А можно поближе фото или подробное описание. Интересный результат. Данные о шумовой бы еще температуре получить....
